building example programs
Wed Feb 18 14:09:33 UTC 2015
On February 18, 2015 8:02:40 AM CST, Gedare Bloom <gedare at rtems.org> wrote:
>Hi Andrew,
>The examples located in testsuites are intended to be compiled with
>RTEMS and will not work by copying them elsewhere. For compiling an
>application, you should have a look at the examples-v2.git repository
>[1]. That should have more info about using RTEMS_MAKEFILE_PATH, and
>also has a newer approach to compiling applications for RTEMS that
>uses the Waf build system. I highly recommend checking out the
>waf-based approach to compiling applications as it has some great
>features, albeit at a slight learning curve.
The examples there are also more oriented to being examples than being part of a test suite. Even ticker is simplified. But there is a simple hello world and others.
>Gedare
>[1] https://git.rtems.org/examples-v2/
>On Tue, Feb 17, 2015 at 8:16 PM, Andrew Harris <andrew.unit at gmail.com>
>wrote:
>> Hello,  I'm trying to figure out how to start a new RTEMS
>application.  I
>> thought I would start by looking at the ticker example.  I copied the
>ticker
>> example but I am not sure how to compile it.  I am not an expert in
>> autoconf/automake and could use some assistance on how to get
>started.  I
>> think I figured out how to configure my RTEMS_MAKEFILE_PATH variable,
>but
>> the only two files in the ticker example are Makefile.am and
>Makefile.in,
>> and I don't know what to do next to build it.  Any help would be
>> appreciated!
>> -andrew
>> users mailing list
>> users at rtems.org
>users mailing list
>users at rtems.org
--joel
