building example programs
Sat Feb 21 20:14:54 UTC 2015
On February 21, 2015 2:02:52 PM CST, Andrew Harris <andrew.unit at gmail.com> wrote:
>Hi Gedare,
>Thanks for the suggestion, I think I understand what you're saying.  I
>went back to the article, and made a slight modification to the
>configure line that was specified; I added a prefix ("just_a_test") to
>see what would happen when I did a make install:
>CONSOLE_POLLED=1 ../rtems-src/configure --target=arm-rtems4.11
>--enable-rtemsbsp="beagleboneblack" --enable-tests
>--prefix=$HOME/development/rtems/just_a_test
>It got pretty far, but I found that there must be an error in one of
>the configuration steps below this call, because it looks like the
>prefix I specified didn't make it all the way down to the BSP, where it
>is still apparently trying to install into /opt/rtems-4.11:
Double check the typing on the --prefix option. The configure script is acting like it wasn't provided.
>Making install in beagleboneblack
>make[2]: Entering directory
>`/home/andrew/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack'
>Making install in .
>make[3]: Entering directory
>make[4]: Entering directory
>make[4]: Nothing to be done for `install-exec-am'.
> /bin/mkdir -p '/opt/rtems-4.11/lib/pkgconfig'
>/bin/mkdir: cannot create directory ‘/opt/rtems-4.11’: Permission
>denied
>make[4]: *** [install-pkgconfigDATA] Error 1
>make[4]: Leaving directory
>make[3]: *** [install-am] Error 2
>make[3]: Leaving directory
>make[2]: *** [install-recursive] Error 1
>make[2]: Leaving directory
>make[1]: *** [install-recursive] Error 1
>make[1]: Leaving directory
>`/home/andrew/development/rtems/b-beagle/arm-rtems4.11/c'
>make: *** [install-recursive] Error 1
>So I'm stuck again; I'm not sure where to look to try to find where the
>prefix argument isn't handed off correctly.
>-andrew
>On Sat, Feb 21, 2015 at 2:20 PM, Gedare Bloom <gedare at rtems.org> wrote:
>Hi Andrew,
>Have you installed the compiled RTEMS and BSPs via "make install" e.g.
>in your ~/development/rtems/b-beagle directory?
>The waf script will only find BSPs that are installed in the directory
>you tell it to look e.g. ~/development/rtems/4.11
>Gedare
>On Sat, Feb 21, 2015 at 9:48 AM, Andrew Harris <andrew.unit at gmail.com>
>wrote:
>> Hello,
>>    Thanks for the useful information.  I'm still having a heck of a
>time
>> getting the examples to build.  I can't seem to get my "waf
>configure" line
>> to work out.  I got RTEMS working from the nice article on this site:
>http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
>> But I fear I don't understand now how to specify the waf configure
>line.
>> I've got it so that it doesn't complain about the RTEMS path, nor
>does it
>> complain about the RTEMS tools path:
>> ~/development/rtems/rtems-tools/waf configure
>> --rtems=$HOME/development/rtems/4.11
>> --rtems-tools=$HOME/development/rtems/4.11
>> But I can't seem to figure out how to tell it to use the
>beagleboneblack
>> BSP.  I have added some print statements into the rtems.py file which
>I
>> believe is used by the waf build system and it doesn't seem to see
>any bsps
>> at all in the paths I've specified above.
>> However, from the website article, it seems to build in such a way as
>to
>> create a b-beagle directory, and deep inside that directory I do see
>a
>> directory that contains a ".pc" file, which I presume is a key file
>for the
>> BSP:
>development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/arm-rtems4.11-beagleboneblack.pc
>> But I can't seem to figure out how to combine this knowledge with the
>> directories that are required for the waf configure step.
>> Has anyone gotten stuck here before?  If so, any help would be
>appreciated!
>> thanks,
>> -andrew
>> On Wed, Feb 18, 2015 at 9:02 AM, Gedare Bloom <gedare at rtems.org>
>wrote:
>>> Hi Andrew,
>>> The examples located in testsuites are intended to be compiled with
>>> RTEMS and will not work by copying them elsewhere. For compiling an
>>> application, you should have a look at the examples-v2.git
>repository
>>> [1]. That should have more info about using RTEMS_MAKEFILE_PATH, and
>>> also has a newer approach to compiling applications for RTEMS that
>>> uses the Waf build system. I highly recommend checking out the
>>> waf-based approach to compiling applications as it has some great
>>> features, albeit at a slight learning curve.
>>> Gedare
>>> [1] https://git.rtems.org/examples-v2/
>>> On Tue, Feb 17, 2015 at 8:16 PM, Andrew Harris
>>> wrote:
>>> > Hello,  I'm trying to figure out how to start a new RTEMS
>application.
>>> > I
>>> > thought I would start by looking at the ticker example.  I copied
>the
>>> > ticker
>>> > example but I am not sure how to compile it.  I am not an expert
>in
>>> > autoconf/automake and could use some assistance on how to get
>started.
>>> > I
>>> > think I figured out how to configure my RTEMS_MAKEFILE_PATH
>variable,
>>> > but
>>> > the only two files in the ticker example are Makefile.am and
>>> > Makefile.in,
>>> > and I don't know what to do next to build it.  Any help would be
>>> > appreciated!
>>> > -andrew
>>> > _______________________________________________
>>> > users mailing list
>>> > users at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
--joel
