building example programs
Andrew Harris
andrew.unit at gmail.com
Sun Feb 22 15:29:38 UTC 2015
Hi Gedare,
That worked, thanks. I was then able to get the "waf configure" step to
work in the examples-v2 directory by using the following line:
~/development/rtems/rtems-tools/waf configure
--rtems=$HOME/development/rtems/just_a_test
--rtems-tools=$HOME/development/rtems/4.11 --rtems-bsps=arm/beagleboneblack
And the waf configure seems to have worked. However, when I try to run the
"waf" step to build everything in examples-v2, it gets really far, but
stops on step 96 of 116 with a linker error. Does this error look like a
configuration problem or is it something that might be just wrong with one
of the examples which I should just skip over? One wierd thing I noticed
was that the "hello-deep.c" file that it was talking about is a filename
with an initial space which threw me for a loop for a minute!
-andrew
[ 95/116] cprogram:
build/arm-rtems4.11-beagleboneblack/posix_api/psx_sched_report/test.c.1.o
build/arm-rtems4.11-beagleboneblack/posix_api/psx_sched_report/psx_sched_report.exe
[ 96/116] cprogram:
build/arm-rtems4.11-beagleboneblack/led/event_server/init.c.1.o ->
build/arm-rtems4.11-beagleboneblack/led/event_server/event_server.exe
/home/andrewha/development/rtems/4.11/bin/arm-rtems4.11-gcc: hello-deep.o:
In function `__wrap_Init':
/home/andrewha/development/examples-v2/build/arm-rtems4.11-beagleboneblack/
hello-deep.c:78: undefined reference to `Init'
/home/andrewha/development/rtems/4.11/bin/arm-rtems4.11-gcc: collect2:
error: ld returned 1 exit status
error: linking: Linker error
Waf: Leaving directory
`/home/andrewha/development/examples-v2/build/arm-rtems4.11-beagleboneblack'
Build failed
-> task in 'hello-deep.texe' failed (exit status 10):
{task 140274785055824: rtrace test.c.2.o -> hello-deep.texe}
['/home/andrewha/development/rtems/4.11/bin/rtems-tld', '-W hello-deep',
'-C', '../../hello/both_hello/hello-deep.ini', '-r',
'/home/andrewha/development/rtems/just_a_test', '-B',
'arm/beagleboneblack', '-c',
'/home/andrewha/development/rtems/4.11/bin/arm-rtems4.11-gcc', '-l',
'/home/andrewha/development/rtems/4.11/bin/arm-rtems4.11-gcc', '--',
'hello/both_hello/test.c.2.o', '-qrtems',
'-B/home/andrewha/development/rtems/just_a_test/arm-rtems4.11/lib/',
'-B/home/andrewha/development/rtems/just_a_test/arm-rtems4.11/beagleboneblack/lib/',
'--specs', 'bsp_specs', '-mcpu=cortex-a8', '-mcpu=cortex-a8', '-o',
'/home/andrewha/development/examples-v2/build/arm-rtems4.11-beagleboneblack/hello/both_hello/hello-deep.texe',
'-Wl,-Bstatic']
On Sun, Feb 22, 2015 at 9:29 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Andrew,
> You probably need to rm -r b-beagle and redo everything from there.
> The old build is probably still in place and being used. (In theory,
> make distclean in b-beagle should work too. But rm is a more certain
> way to clean.)
> Gedare
> On Sat, Feb 21, 2015 at 3:27 PM, Andrew Harris <andrew.unit at gmail.com>
> wrote:
> > Hi Joel,
> > Thanks for the response, I don't think I see anything wrong with the
> > typing. When I run the configure line I mentioned, and then do make
> > install, I actually get a bin/ directory in the "just_a_test" directory
> that
> > I set as the prefix, and it has the following files in it:
> > "arm-rtems4.11-difftest arm-rtems4.11-sorttimes cklength eolstrip
> > install-if-change packhex rtems-bin2c unhex". It's not until it gets
> to
> > the beagleboneblack step that it seems the prefix isn't propagated.
> > -andrew
> > On Sat, Feb 21, 2015 at 3:14 PM, Joel Sherrill <
> joel.sherrill at oarcorp.com>
> > wrote:
> >> On February 21, 2015 2:02:52 PM CST, Andrew Harris <
> >> wrote:
> >> >Hi Gedare,
> >> >Thanks for the suggestion, I think I understand what you're saying. I
> >> >went back to the article, and made a slight modification to the
> >> >configure line that was specified; I added a prefix ("just_a_test") to
> >> >see what would happen when I did a make install:
> >> >CONSOLE_POLLED=1 ../rtems-src/configure --target=arm-rtems4.11
> >> >--enable-rtemsbsp="beagleboneblack" --enable-tests
> >> >--prefix=$HOME/development/rtems/just_a_test
> >> >It got pretty far, but I found that there must be an error in one of
> >> >the configuration steps below this call, because it looks like the
> >> >prefix I specified didn't make it all the way down to the BSP, where it
> >> >is still apparently trying to install into /opt/rtems-4.11:
> >> Double check the typing on the --prefix option. The configure script is
> >> acting like it wasn't provided.
> >> >Making install in beagleboneblack
> >> >make[2]: Entering directory
> >`/home/andrew/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack'
> >> >Making install in .
> >> >make[3]: Entering directory
> >> >make[4]: Entering directory
> >> >make[4]: Nothing to be done for `install-exec-am'.
> >> > /bin/mkdir -p '/opt/rtems-4.11/lib/pkgconfig'
> >> >/bin/mkdir: cannot create directory ‘/opt/rtems-4.11’: Permission
> >> >denied
> >> >make[4]: *** [install-pkgconfigDATA] Error 1
> >> >make[4]: Leaving directory
> >> >make[3]: *** [install-am] Error 2
> >> >make[3]: Leaving directory
> >> >make[2]: *** [install-recursive] Error 1
> >> >make[2]: Leaving directory
> >> >make[1]: *** [install-recursive] Error 1
> >> >make[1]: Leaving directory
> >> >`/home/andrew/development/rtems/b-beagle/arm-rtems4.11/c'
> >> >make: *** [install-recursive] Error 1
> >> >So I'm stuck again; I'm not sure where to look to try to find where the
> >> >prefix argument isn't handed off correctly.
> >> >-andrew
> >> >On Sat, Feb 21, 2015 at 2:20 PM, Gedare Bloom <gedare at rtems.org>
> wrote:
> >> >Hi Andrew,
> >> >Have you installed the compiled RTEMS and BSPs via "make install" e.g.
> >> >in your ~/development/rtems/b-beagle directory?
> >> >The waf script will only find BSPs that are installed in the directory
> >> >you tell it to look e.g. ~/development/rtems/4.11
> >> >Gedare
> >> >On Sat, Feb 21, 2015 at 9:48 AM, Andrew Harris <andrew.unit at gmail.com>
> >> >wrote:
> >> >> Hello,
> >> >> Thanks for the useful information. I'm still having a heck of a
> >> >time
> >> >> getting the examples to build. I can't seem to get my "waf
> >> >configure" line
> >> >> to work out. I got RTEMS working from the nice article on this site:
> http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
> >> >> But I fear I don't understand now how to specify the waf configure
> >> >line.
> >> >> I've got it so that it doesn't complain about the RTEMS path, nor
> >> >does it
> >> >> complain about the RTEMS tools path:
> >> >> --rtems=$HOME/development/rtems/4.11
> >> >> But I can't seem to figure out how to tell it to use the
> >> >beagleboneblack
> >> >> BSP. I have added some print statements into the rtems.py file which
> >> >I
> >> >> believe is used by the waf build system and it doesn't seem to see
> >> >any bsps
> >> >> at all in the paths I've specified above.
> >> >> However, from the website article, it seems to build in such a way as
> >> >to
> >> >> create a b-beagle directory, and deep inside that directory I do see
> >> >a
> >> >> directory that contains a ".pc" file, which I presume is a key file
> >> >for the
> >> >> BSP:
> >development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/arm-rtems4.11-beagleboneblack.pc
> >> >> But I can't seem to figure out how to combine this knowledge with the
> >> >> directories that are required for the waf configure step.
> >> >> Has anyone gotten stuck here before? If so, any help would be
> >> >appreciated!
> >> >> thanks,
> >> >> -andrew
> >> >> On Wed, Feb 18, 2015 at 9:02 AM, Gedare Bloom <gedare at rtems.org>
> >> >wrote:
> >> >>> Hi Andrew,
> >> >>> The examples located in testsuites are intended to be compiled with
> >> >>> RTEMS and will not work by copying them elsewhere. For compiling an
> >> >>> application, you should have a look at the examples-v2.git
> >> >repository
> >> >>> [1]. That should have more info about using RTEMS_MAKEFILE_PATH, and
> >> >>> also has a newer approach to compiling applications for RTEMS that
> >> >>> uses the Waf build system. I highly recommend checking out the
> >> >>> waf-based approach to compiling applications as it has some great
> >> >>> features, albeit at a slight learning curve.
> >> >>> Gedare
> >> >>> [1] https://git.rtems.org/examples-v2/
> >> >>> On Tue, Feb 17, 2015 at 8:16 PM, Andrew Harris
> >> >>> wrote:
> >> >>> > Hello, I'm trying to figure out how to start a new RTEMS
> >> >application.
> >> >>> > I
> >> >>> > thought I would start by looking at the ticker example. I copied
> >> >the
> >> >>> > ticker
> >> >>> > example but I am not sure how to compile it. I am not an expert
> >> >in
> >> >>> > autoconf/automake and could use some assistance on how to get
> >> >started.
> >> >>> > I
> >> >>> > think I figured out how to configure my RTEMS_MAKEFILE_PATH
> >> >variable,
> >> >>> > but
> >> >>> > the only two files in the ticker example are Makefile.am and
> >> >>> > Makefile.in,
> >> >>> > and I don't know what to do next to build it. Any help would be
> >> >>> > appreciated!
> >> >>> > -andrew
> >> >>> > _______________________________________________
> >> >>> > users mailing list
> >> >>> > users at rtems.org
> >> >>> > http://lists.rtems.org/mailman/listinfo/users
> >> >> users mailing list
> >> >> users at rtems.org
> >> --joel
URL: <http://lists.rtems.org/pipermail/users/attachments/20150222/6d85395b/attachment-0001.html>
