building example programs
Sun Feb 22 15:43:57 UTC 2015
On February 22, 2015 10:41:55 AM EST, Andrew Harris <andrew.unit at gmail.com> wrote:
>On Sun, Feb 22, 2015 at 10:34 AM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>On February 22, 2015 10:29:38 AM EST, Andrew Harris
>>Hi Gedare,
>>That worked, thanks.  I was then able to get the "waf configure" step
>>to work in the examples-v2 directory by using the following line:
>>~/development/rtems/rtems-tools/waf configure
>>--rtems=$HOME/development/rtems/just_a_test
>>--rtems-tools=$HOME/development/rtems/4.11
>>--rtems-bsps=arm/beagleboneblack
>>And the waf configure seems to have worked.  However, when I try to
>run
>>the "waf" step to build everything in examples-v2, it gets really far,
>>but stops on step 96 of 116 with a linker error.  Does this error look
>>like a configuration problem or is it something that might be just
>>wrong with one of the examples which I should just skip over?  One
>>wierd thing I noticed was that the "hello-deep.c" file that it was
>>talking about is a filename with an initial space which threw me for a
>>loop for a minute!
>I think this may be a recent modification of a simple example to show
>off the trace linker. There is a PR I think to revert that change.
>Did fixing the space let it continue?
>Hi Joel,
>The hello-deep.c file seems to be autogenerated, so I'm not quite sure
>where to look to fix it.  If you have a suggestion on where to look I
>can give it a try.
I am in the Atlanta airport so would recommend just dropping the directory out of the set built.
>-andrew
--joel
