Lite5200
Brad Andrews
bandrews at activepower.com
Sun Feb 22 17:32:41 UTC 2015
I'm having trouble running ticker and hello examples on my Lite5200 rev 2 board.
Each time it transfers to rtems at location 4000, it resets U-boot.
See below - Ticker and Test (test is hello example)
Any suggestions?
=> tftp Ticker.img
Using FEC device
TFTP from server 192.168.1.18; our IP address is 192.168.1.17
Filename 'Ticker.img'.
Load address: 0x1000000
Loading: ######
2.4 MiB/s
done
Bytes transferred = 74620 (1237c hex)
=> bootm
## Booting kernel from Legacy Image at 01000000 ...
Image Name: RTEMS
Created: 2015-02-22 16:57:08 UTC
Image Type: PowerPC RTEMS Kernel Image (gzip compressed)
Data Size: 74556 Bytes = 72.8 KiB
Load Address: 00040000
Entry Point: 00040000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
## Transferring control to RTEMS (at address 00040000) ...
U-Boot 2014.01 (Feb 21 2015 - 20:53:53)
CPU: MPC5200 v1.2, Core v1.1 at 396 MHz
Bus 132 MHz, IPB 66 MHz, PCI 33 MHz
Board: Motorola MPC5200 (IceCube)
I2C: 85 kHz, ready
DRAM: 64 MiB
Flash: 16 MiB
PCI: Bus Dev VenId DevId Class Int
00:1a.0 - 1057:5803 - Bridge device
In: serial
Out: serial
Err: serial
Net: FEC
IDE: Bus 0: not available
Type run flash_nfs to mount root filesystem over NFS
Hit any key to stop autoboot: 0
=> tftp 1000000 Test.img
Using FEC device
Filename 'Test.img'.
Loading: ####
2.2 MiB/s
done
Bytes transferred = 48007 (bb87 hex)
=> bootm
Image Name: RTEMS
Created: 2015-02-22 17:17:27 UTC
Data Size: 47943 Bytes = 46.8 KiB
I2C: 85 kHz, ready
DRAM: 64 MiB
Flash: 16 MiB
In: serial
Out: serial
Err: serial
Net: FEC
This email has been scanned for email related threats and delivered safely by Mimecast.
For more information please visit http://www.mimecast.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20150222/ff0e1352/attachment.html>
