Lite5200
Sun Feb 22 18:17:07 UTC 2015
On 22/02/15 18:32, Brad Andrews wrote:
> I'm having trouble running ticker and hello examples on my Lite5200 rev 2 board.
> Each time it transfers to rtems at location 4000, it resets U-boot.
> See below - Ticker and Test (test is hello example)
> Any suggestions?
I would check the startup code with a debugger, otherwise check the load
and entry address if this the one of the ELF file. Is the board info
passed by U-Boot correct?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
