Lite5200
Sun Feb 22 21:49:00 UTC 2015
On February 22, 2015 1:17:07 PM EST, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>On 22/02/15 18:32, Brad Andrews wrote:
>> I'm having trouble running ticker and hello examples on my Lite5200
>rev 2 board.
>> Each time it transfers to rtems at location 4000, it resets U-boot.
>> See below - Ticker and Test (test is hello example)
>> Any suggestions?
>I would check the startup code with a debugger, otherwise check the
>load
>and entry address if this the one of the ELF file. Is the board info
>passed by U-Boot correct?
If this is the Freescale board, Uboot lied about the amount of memory in a board we have at OAR. Check that the base address of flash and ram along with the lengths match what you think it is.
--joel
