SMP on Xilinx Zynq
Maldonado, Sergio E. smaldona at slac.stanford.edu
Sat Feb 28 20:37:32 UTC 2015
I have CONFIGURE_SMP_MAXIMUM_PROCESSORS set to 2 and defined the symbol bsp_processor_count, also 2.
Sometime last year, I was able to get SMP working with both cores, but I see that the RTEMS code base has advanced significantly since.
Thanks,
Sergio
On Feb 28, 2015, at 12:27 PM, Joel Sherrill <joel.sherrill at OARcorp.com>
 wrote:
> On February 28, 2015 12:38:54 PM CST, "Maldonado, Sergio E." <smaldona at slac.stanford.edu> wrote:
>> Hello,
>> Attempting to get SMP working on my Xilinx Zynq platform.
>> I'm currently running RTEMS compiled from the head of the git repo
>> master branch (as of 2/28/15), so I should have the latest updates.
>> The problem I have is that multitasking does not work when both cores
>> are enabled.
>> I'm looking for some input on what could be going wrong and how to fix
>> it.
>> Scenario:
>> At system boot, I can verify that core 0 completes RTEMS boot_card
>> initialization, and starts multitasking.
>> However, Core 0 does _not_ execute the Init task entry point and
>> instead goes straight to its idle loop.
>> Meanwhile, Core 1 starts and executes until it reaches the first
>> _CPU_Context_Switch/_CPU_Context_Restore call.
>> If I step into Core 1, I can see that it never returns from this
>> routine and stays in an infinite loop of the following instructions
> Did you configure multiple cores? There are SMP specific configuration parameters such as number of cores in the system.
>> 83		bne	.L_check_thread_dispatch_necessary
>> (gdb) s
>> at
>> ../../../../../../../../src/c/src/../../cpukit/score/cpu/arm/cpu_asm.S:131
>> 131		GET_SELF_CPU_CONTROL	r2, r3
>> (gdb) s
>> at
>> ../../../../../../../../src/c/src/../../cpukit/score/cpu/arm/cpu_asm.S:134
>> 134		ldrb	r4, [r2, #PER_CPU_DISPATCH_NEEDED]
>> (gdb) s
>> at
>> ../../../../../../../../src/c/src/../../cpukit/score/cpu/arm/cpu_asm.S:135
>> 135		cmp	r4, #0
>> (gdb) s
>> at
>> ../../../../../../../../src/c/src/../../cpukit/score/cpu/arm/cpu_asm.S:136
>> 136		beq	.L_check_is_executing
>> (gdb) s
>> at
>> ../../../../../../../../src/c/src/../../cpukit/score/cpu/arm/cpu_asm.S:80
>> 80		add	r3, r1, #ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET
>> (gdb) s
>> at
>> ../../../../../../../../src/c/src/../../cpukit/score/cpu/arm/cpu_asm.S:81
>> 81		ldrexb	r4, [r3]
>> (gdb) s
>> at
>> ../../../../../../../../src/c/src/../../cpukit/score/cpu/arm/cpu_asm.S:82
>> 82		cmp	r4, #0
>> (gdb) s
>> at
>> ../../../../../../../../src/c/src/../../cpukit/score/cpu/arm/cpu_asm.S:83
>> (gdb) s
>> at
>> (gdb) s
>> Consequently, the Init task entry point is never executed by either
>> core, and the system does not complete startup.
>> Any thoughts on why Core 1 will not complete its transition to
>> multitasking?
>> Here's a piece of information that might be useful:
>> When I configure RTEMS SMP with just 1 processor, the system
>> successfully starts multitasking and the Init task entry point _does_
>> get executed by Core 0.
>> Thank you,
>> Sergio Maldonado - SLAC
>> users mailing list
>> users at rtems.org
> --joel
