building example programs
Andrew Harris andrew.unit at gmail.com
Sat Feb 21 20:02:52 UTC 2015
Hi Gedare,
   Thanks for the suggestion, I think I understand what you're saying.  I
went back to the article, and made a slight modification to the configure
line that was specified; I added a prefix ("just_a_test") to see what would
happen when I did a make install:
CONSOLE_POLLED=1 ../rtems-src/configure --target=arm-rtems4.11
--enable-rtemsbsp="beagleboneblack" --enable-tests
--prefix=$HOME/development/rtems/just_a_test
It got pretty far, but I found that there must be an error in one of the
configuration steps below this call, because it looks like the prefix I
specified didn't make it all the way down to the BSP, where it is still
apparently trying to install into /opt/rtems-4.11:
Making install in beagleboneblack
make[2]: Entering directory
`/home/andrew/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack'
Making install in .
make[3]: Entering directory
make[4]: Entering directory
make[4]: Nothing to be done for `install-exec-am'.
 /bin/mkdir -p '/opt/rtems-4.11/lib/pkgconfig'
/bin/mkdir: cannot create directory ‘/opt/rtems-4.11’: Permission denied
make[4]: *** [install-pkgconfigDATA] Error 1
make[4]: Leaving directory
make[3]: *** [install-am] Error 2
make[3]: Leaving directory
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory
`/home/andrew/development/rtems/b-beagle/arm-rtems4.11/c'
make: *** [install-recursive] Error 1
So I'm stuck again; I'm not sure where to look to try to find where the
prefix argument isn't handed off correctly.
-andrew
On Sat, Feb 21, 2015 at 2:20 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Hi Andrew,
> Have you installed the compiled RTEMS and BSPs via "make install" e.g.
> in your ~/development/rtems/b-beagle directory?
> The waf script will only find BSPs that are installed in the directory
> you tell it to look e.g. ~/development/rtems/4.11
> Gedare
> On Sat, Feb 21, 2015 at 9:48 AM, Andrew Harris <andrew.unit at gmail.com>
> wrote:
> > Hello,
> >    Thanks for the useful information.  I'm still having a heck of a time
> > getting the examples to build.  I can't seem to get my "waf configure"
> line
> > to work out.  I got RTEMS working from the nice article on this site:
> http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
> > But I fear I don't understand now how to specify the waf configure line.
> > I've got it so that it doesn't complain about the RTEMS path, nor does it
> > complain about the RTEMS tools path:
> > ~/development/rtems/rtems-tools/waf configure
> > --rtems=$HOME/development/rtems/4.11
> > --rtems-tools=$HOME/development/rtems/4.11
> > But I can't seem to figure out how to tell it to use the beagleboneblack
> > BSP.  I have added some print statements into the rtems.py file which I
> > believe is used by the waf build system and it doesn't seem to see any
> bsps
> > at all in the paths I've specified above.
> > However, from the website article, it seems to build in such a way as to
> > create a b-beagle directory, and deep inside that directory I do see a
> > directory that contains a ".pc" file, which I presume is a key file for
> the
> > BSP:
> development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/arm-rtems4.11-beagleboneblack.pc
> > But I can't seem to figure out how to combine this knowledge with the
> > directories that are required for the waf configure step.
> > Has anyone gotten stuck here before?  If so, any help would be
> appreciated!
> > thanks,
> > -andrew
> > On Wed, Feb 18, 2015 at 9:02 AM, Gedare Bloom <gedare at rtems.org> wrote:
> >> Hi Andrew,
> >> The examples located in testsuites are intended to be compiled with
> >> RTEMS and will not work by copying them elsewhere. For compiling an
> >> application, you should have a look at the examples-v2.git repository
> >> [1]. That should have more info about using RTEMS_MAKEFILE_PATH, and
> >> also has a newer approach to compiling applications for RTEMS that
> >> uses the Waf build system. I highly recommend checking out the
> >> waf-based approach to compiling applications as it has some great
> >> features, albeit at a slight learning curve.
> >> Gedare
> >> [1] https://git.rtems.org/examples-v2/
> >> On Tue, Feb 17, 2015 at 8:16 PM, Andrew Harris <andrew.unit at gmail.com>
> >> wrote:
> >> > Hello,  I'm trying to figure out how to start a new RTEMS application.
> >> > I
> >> > thought I would start by looking at the ticker example.  I copied the
> >> > ticker
> >> > example but I am not sure how to compile it.  I am not an expert in
> >> > autoconf/automake and could use some assistance on how to get started.
> >> > I
> >> > think I figured out how to configure my RTEMS_MAKEFILE_PATH variable,
> >> > but
> >> > the only two files in the ticker example are Makefile.am and
> >> > Makefile.in,
> >> > and I don't know what to do next to build it.  Any help would be
> >> > appreciated!
> >> > -andrew
> >> > _______________________________________________
> >> > users mailing list
> >> > users at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> > users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150221/08e68649/attachment-0002.html>
