building example programs
Andrew Harris andrew.unit at gmail.com
Sun Feb 22 15:41:55 UTC 2015
On Sun, Feb 22, 2015 at 10:34 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On February 22, 2015 10:29:38 AM EST, Andrew Harris <andrew.unit at gmail.com>
> wrote:
> >Hi Gedare,
> >That worked, thanks.  I was then able to get the "waf configure" step
> >to work in the examples-v2 directory by using the following line:
> >~/development/rtems/rtems-tools/waf configure
> >--rtems=$HOME/development/rtems/just_a_test
> >--rtems-tools=$HOME/development/rtems/4.11
> >--rtems-bsps=arm/beagleboneblack
> >And the waf configure seems to have worked.  However, when I try to run
> >the "waf" step to build everything in examples-v2, it gets really far,
> >but stops on step 96 of 116 with a linker error.  Does this error look
> >like a configuration problem or is it something that might be just
> >wrong with one of the examples which I should just skip over?  One
> >wierd thing I noticed was that the "hello-deep.c" file that it was
> >talking about is a filename with an initial space which threw me for a
> >loop for a minute!
> I think this may be a recent modification of a simple example to show off
> the trace linker. There is a PR I think to revert that change.
> Did fixing the space let it continue?
Hi Joel,
   The hello-deep.c file seems to be autogenerated, so I'm not quite sure
where to look to fix it.  If you have a suggestion on where to look I can
give it a try.
-andrew
URL: <http://lists.rtems.org/pipermail/users/attachments/20150222/7bc762bd/attachment-0002.html>
