Signal handler in RTEMS
Nick Withers nick.withers at anu.edu.au
Sat Jan 3 01:53:42 UTC 2015
Hello Ben,
I'm not an RTEMS internals expert, but thought I'd try to answer this
anyway - hopefully an expert will chime in to confirm / correct me :-)
On Wed, 2014-12-31 at 13:32 -0800, Ben Dart wrote:
> void HandleAndPrintSignal()
>       printf("I am in the segfault signal handler AND I WILL HANDLE YOUR SIG!!!!\n");
>       while(1){ printf("LALALA\n"); }
>       exit(1);
> void *POSIX_Init(void *args)
>       printf("BENS BIG NOTE: Initializing Signal Handler\n");
>       struct sigaction sa;
>       sa.sa_handler = HandleAndPrintSignal;
>       sigemptyset(&sa.sa_mask);
>       sa.sa_flags = SA_SIGINFO;
>       if (sigaction (SIGSEGV, &sa, 0)) {
>             printf("A ERROR OCCURED WITH THIS!");
>             exit(1);
>       int *p = NULL;
>       while(1)
>             printf("Doing some looping\n");
>             *(p--) = 5;
>             printf("%d", *p);
> This will cause a seg fault as expected.
No it won't.
It'll cause a CPU exception, which is what you're seeing.
RTEMS uses a single-process model; there's no "segmentation" / memory
protection between processes (since, again, there's no such thing as
multiple processes).
> However instead of being caught by the signal handler a kernel routine under vectors_init.c will print the following stack trace:
> Exception handler called for exception 12 (0xC)
>          Next PC or Address of fault = 003506BC
>          Saved MSR = 00003012
>          Context: Task ID 0x0B010001
>          R0  = 003506B8 R1  = 06827C58 R2  = 004A54F8 R3  = 00000000
>          R4  = 06827BE8 R5  = 00000013 R6  = 06827C84 R7  = 00000001
>          R8  = 00000000 R9  = 00000800 R10 = F0002000 R11 = F0002000
>          R12 = 25555582 R13 = 0051A7C0 R14 = 55555555 R15 = 55555555
>          R16 = 55555555 R17 = 55555555 R18 = 55555555 R19 = 55555555
>          R20 = 55555555 R21 = 55555555 R22 = 06827F10 R23 = 00000001
>          R24 = 06827D78 R25 = 003CD20C R26 = 06827D94 R27 = 00000000
>          R28 = 006FF698 R29 = 00000013 R30 = 00000000 R31 = 1A01000E
>          CR  = 45555582
>          CTR = 00350EB0
>          XER = 00000000
>          LR  = 003506B8
>          DAR = 00000000
> Stack Trace:
>   IP: 0x003506BC, LR: 0x003506B8
> --^ 0x0038C364--^ 0x00389AF0--^ 0x0036BC5C--^ 0x00350F70--^ 0x0038AD78
> --^ 0x0036071C--^ 0x0036D330--^ 0x0036D3B0--^ 0x0033E514--^ 0x003399D0
> --^ 0x0033B4F0--^ 0x0033D80C--^ 0x0019B68C--^ 0x003C6934--^ 0x003C6850
> Suspending faulting task (0x0B010001)
> Is there something special that needs to be done to set up signal handlers for RTEMS? It seems like from this manual:
> http://docs.rtems.org/doc-current/share/rtems/pdf/posix1003_1.pdf <http://docs.rtems.org/doc-current/share/rtems/pdf/posix1003_1.pdf%20under%20section%203.3.1.1>
> under section 3.3.1.1 indicates that signals have been implemented.
> Is there something that I am doing wrong?
You'll never get a segfault under RTEMS. That doesn't mean that invalid
accesses to memory are "OK" though.
Does that make sense?
Nick Withers
Embedded Systems Programmer
Department of Nuclear Physics, Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
