Compression and decompression CPU usage in Leon 3
angelo fraietta newsgroups at smartcontroller.com.au
Mon Jan 12 21:10:06 UTC 2015
Check that there is not a critical section running within the algorithm
On 13/01/2015 5:39 AM, Rafael Morales wrote:
> Dear all,
> I'm using a Leon 3 with RTEMS 4.10.
> When I run a compression/decompression algorithm (zlib or promDecode
> from mkprom sources) on KB of data,
> my other RTEMS tasks seems to be frozen.
> I've tried to put the compression/decompression in a separate task
> with low priority, but no luck.
> In theory, a more privileged task should stop the compression and
> start to run, but I see just the opposite.
> Any idea?
> Thanks in advance.
> users mailing list
> users at rtems.org
This email has been checked for viruses by Avast antivirus software.
http://www.avast.com
