Compression and decompression CPU usage in Leon 3
Rafael Morales rmorales at iaa.es
Mon Jan 12 21:33:08 UTC 2015
Dear Angelo,
Thank you for your response.
I've checked and there is no critical sections inside code. Just nested
"for" and memory buffers playing.
Saludos Rafael.
> Check that there is not a critical section running within the algorithm
> On 13/01/2015 5:39 AM, Rafael Morales wrote:
>> Dear all,
>> I'm using a Leon 3 with RTEMS 4.10.
>> When I run a compression/decompression algorithm (zlib or promDecode
>> from mkprom sources) on KB of data,
>> my other RTEMS tasks seems to be frozen.
>> I've tried to put the compression/decompression in a separate task
>> with low priority, but no luck.
>> In theory, a more privileged task should stop the compression and
>> start to run, but I see just the opposite.
>> Any idea?
>> Thanks in advance.
>> users mailing list
>> users at rtems.org
> This email has been checked for viruses by Avast antivirus software.
> http://www.avast.com
