List of Hardware boards
angelo fraietta newsgroups at smartcontroller.com.au
Wed Jan 14 21:09:52 UTC 2015
Thanks
I will need to run 7 I2S devices in parallel, so I thought I might treat
them like a big parallel bus. I had a look at Rasberry PI as it has a
faster processing speed than NXP, and is significantly cheaper.
I remember discussion a while back on Raspberry PI but I don't know the
status. Is there a BSP for that for RTMES that supports Network and
monitor. I don't need USB or disk storage.
Thanks
On 14/01/2015 5:20 PM, Sebastian Huber wrote:
> Hello,
> you may have a look at the LPC1700 or LPC4000 chips from NXP. They
> have an I2S module which may simplify things for you.
> On 14/01/15 04:08, angelo fraietta wrote:
>> Greetings
>> Is there a list of hardware boards that run RTEMS. I am targeting a
>> board where I can do interrupts at about 1.5Mhz because I will be
>> using an I2S input at 48Khz sample rate.
>> Any suggestions on a board?
>> Thanks
>> This email has been checked for viruses by Avast antivirus software.
>> http://www.avast.com
>> users mailing list
>> users at rtems.org
