MVME3100: RTEMS Shell input doesn't appear (fine under psim)
Mon Jan 19 16:56:01 UTC 2015
On 1/19/2015 7:46 AM, Gedare Bloom wrote:
> Since it worked 6 months ago for you, I recommend you "git-bisect" to
> find where it broke.
Just going through the git log, I see a few changes which could have
impacted
this BSP. A lot of warning cleanup and a commit about interrupts. Nothing
jumps out though. Try back in time until it worked and then...
git bisect is your friend. :)
--joel
> -Gedare
> On Mon, Jan 19, 2015 at 1:19 AM, Nick Withers <nick.withers at anu.edu.au> wrote:
>> Hello all,
>> I haven't used the RTEMS Shell for a while now (6 months?) but had cause
>> to again today to try to troubleshoot another problem.
>> On the MVME3100, it no longer wants to accept my console input, not even
>> echoing it. Not an issue under psim, however...
>> I've attached my minimal-ish test program (build with, e.g.: "gmake
>> BSP=psim RTEMS_VER=4.11 RTEMS_ROOT=/opt/rtems-4.11").
>> Any ideas? Good ol' termios?
>> Nick Withers
>> Embedded Systems Programmer
>> Department of Nuclear Physics, Research School of Physics and Engineering
>> The Australian National University (CRICOS: 00120C)
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
