Raspberry Pi LEDs
Fri Jan 30 03:35:08 UTC 2015
On January 29, 2015 10:59:31 AM CST, "André Marques" <andre.lousa.marques at gmail.com> wrote:
>On 29-01-2015 12:38, Joel Sherrill wrote:
>> Hi
>> I was looking at the led examples on the Pi. Do I need to hook up an
>external LED?
>The ACT led (which would be used to indicate SD card activity) is
>hardwired to GPIO 16, so you may be able to use it (it works on my
>model
>B), otherwise you need to use an external LED.
>The other board LEDs are hardwired either to the power supply
>(unusable)
>or the ethernet/usb chip.
That's what Pierre's code in led.h in examples-v2 appears to be doing but we have no blink. I switched the commented out part to the B+.
 Maybe tomorrow morning I can double check.
>--André.
>> Any hints more than the code?
>> --joel
>> users mailing list
>> users at rtems.org
--joel
