Source-builder MacOS and python2.7 - again.
Thu Jan 8 22:00:53 UTC 2015
On 1/8/2015 3:52 PM, Mr. Andrei Chichak wrote:
> I’m installing the head of RTEMS onto a Mac OSX 10.10.1 (Yosemite) box.
> I use the following script to grab the latest copy of source-builder
> and get stuff set up for ARM:
>  cd
>   mkdir -p development/rtems/src
>   cd development/rtems/src
>   git clone git://git.rtems.org/rtems-source-builder.git
>   cd rtems-source-builder
>   source-builder/sb-check
>   cd rtems
>   ../source-builder/sb-set-builder --list-bsets
>   ../source-builder/sb-set-builder —log=l-arm.txt
> —prefix=$HOME/development/rtems/4.11 4.11/rtems-arm
> (verbose, and meant for puny humans, but it got the job done on my laptop)
> After about an hour the build bombs on not finding a reasonable
> version of python2.7. (log fragment at bottom)
> uws105675usr:~ andreichichak$ python -V
> Python 2.7.9
> uws105675usr:~ andreichichak$ python2.7 -V
> Python 2.7.9
> uws105675usr:~ andreichichak$ which python
> /Library/Frameworks/Python.framework/Versions/2.7/bin/python
> uws105675usr:~ andreichichak$ which python2.7
> /Library/Frameworks/Python.framework/Versions/2.7/bin/python2.7
> I’m not sure what the problem could be. I tried installing python
> 2.7.[2 4 5 7 9] and all bomb with the same result.
> I installed the latest Xcode and command line tools and got macports
> up to date (for xz and cvs).
> Any ideas, or at least does anyone have a command that I can issue
> that can fail in less than an hour?
I think the gdb probe to find Python 2.7 development libraries is failing.
There should be a config.log in the directory of the failure. See what
it failed about specifically.  You may just be missing something to install
on your host.
Chris will be awake soon and may have more insight on the Mac and RSB. :)
> Thanks,
> Andrei
> Final l-arm.txt fragment :
> === configuring in build-gnulib
> (/Users/andreichichak/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gdb-7.8.1-1/build/gdb/build-gnulib)
> configure: running /bin/sh ../../../gdb-7.8.1/gdb/gnulib/configure
> --disable-option-checking
> '--prefix=/Users/andreichichak/development/rtems/4.11'
> '--with-system-zlib' '--verbose' '--disable-nls'
> '--without-included-gettext' '--disable-win32-registry'
> '--disable-werror' '--enable-sim' '--without-zlib' '--with-expat'
> '--with-python'
> '--bindir=/Users/andreichichak/development/rtems/4.11/bin'
> '--exec-prefix=/Users/andreichichak/development/rtems/4.11'
> '--includedir=/Users/andreichichak/development/rtems/4.11/include'
> '--libdir=/Users/andreichichak/development/rtems/4.11/lib'
> '--mandir=/Users/andreichichak/development/rtems/4.11/share/man'
> '--infodir=/Users/andreichichak/development/rtems/4.11/share/info'
> '--program-transform-name=s&^&arm-rtems4.11-&'
> '--build=x86_64-apple-darwin14.0.0' '--host=x86_64-apple-darwin14.0.0'
> '--target=arm-rtems4.11' 'build_alias=x86_64-apple-darwin14.0.0'
> 'host_alias=x86_64-apple-darwin14.0.0' 'target_alias=arm-rtems4.11'
> 'CC=/usr/bin/cc -O2 -pipe -fbracket-depth=1024
> -I/Users/andreichichak/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-andreichichak/4.11/rtems-arm/Users/andreichichak/development/rtems/4.11/include'
> 'CFLAGS=-g -O2' 'LDFLAGS= -Wl,-no_pie
> -L/Users/andreichichak/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-andreichichak/4.11/rtems-arm/Users/andreichichak/development/rtems/4.11/lib'
> 'MAKEINFO=makeinfo --split-size=5000000' 'YACC=bison -y'
> --cache-file=./config.cache --srcdir=../../../gdb-7.8.1/gdb/gnulib
> configure: creating cache ./config.cache
> dot dot dot
> checking for shared library run path origin… done
> checking for libexpat... yes
> checking how to link with libexpat...
> -L/Users/andreichichak/development/rtems/4.11/lib -lexpat
> checking for XML_StopParser... yes
> checking whether to use python... yes
> checking for python...
> checking for python2.7... no
> configure: error: python is missing or unusable
> make[1]: *** [configure-gdb] Error 1
> make: *** [all] Error 2
> shell cmd failed: /bin/sh -ex
> /Users/andreichichak/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gdb-7.8.1-1/doit
> error: building arm-rtems4.11-gdb-7.8.1-1
>   See error report: rsb-report-arm-rtems4.11-gdb-7.8.1-1.txt
> Build Set: Time 1:00:56.329867
> Final rsb-report-arm-rtems4.11-gdb-7.8.1-1.txt fragment:
URL: <http://lists.rtems.org/pipermail/users/attachments/20150108/89f65063/attachment-0002.html>
