Compression and decompression CPU usage in Leon 3
Rafael Morales
rmorales at iaa.es
Wed Jan 14 14:04:45 UTC 2015
Dear all,
Thank you for you responses.
Finally I found the problem: priority assigned to tasks were not well
defined.
Once is was solved, the compression task worked as expected.
I've attached a small sample that allows to play with compression and
priorities tasks.
I hope that someone find useful If she/he has similar problems.
Saludos from Spain.
> On 1/12/2015 3:33 PM, Rafael Morales wrote:
>> Dear Angelo,
>> Thank you for your response.
>> I've checked and there is no critical sections inside code. Just nested
>> "for" and memory buffers playing.
> Any chance the thread doing the compression is non-preemptible?
>> Saludos Rafael.
>>> Check that there is not a critical section running within the algorithm
>>> On 13/01/2015 5:39 AM, Rafael Morales wrote:
>>>> Dear all,
>>>> I'm using a Leon 3 with RTEMS 4.10.
>>>> When I run a compression/decompression algorithm (zlib or promDecode
>>>> from mkprom sources) on KB of data,
>>>> my other RTEMS tasks seems to be frozen.
>>>> I've tried to put the compression/decompression in a separate task
>>>> with low priority, but no luck.
>>>> In theory, a more privileged task should stop the compression and
>>>> start to run, but I see just the opposite.
>>>> Any idea?
>>>> Thanks in advance.
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
>>> This email has been checked for viruses by Avast antivirus software.
>>> http://www.avast.com
>> users mailing list
>> users at rtems.org
/* Test_task
//function prototypes
rtems_task Init(rtems_task_argument argument);
rtems_task task_1(rtems_task_argument unused);
rtems_task task_2(rtems_task_argument unused);
rtems_task task_3(rtems_task_argument unused);
rtems_task task_4(rtems_task_argument unused);
void create_compression_buffer();
//glbal variables
rtems_id Task_id[ 4 ]; /* array of task ids */
rtems_name Task_name[ 4 ]; /* array of task names */
//RTEMS configuration
#define CONFIGURE_INIT
#include <bsp.h> /* for device driver prototypes */
/* configuration information */
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER 1
#define CONFIGURE_MAXIMUM_TASKS 16
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_EXTRA_TASK_STACKS (20 * RTEMS_MINIMUM_STACK_SIZE)
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
#define CONFIGURE_INIT_TASK_PRIORITY 100
#define CONFIGURE_MAXIMUM_DRIVERS 16
/* Configure RTEMS Kernel */
#include <rtems/confdefs.h>
/* Configure Driver manager */
#if defined(RTEMS_DRVMGR_STARTUP) && defined(LEON3) /* if --drvmgr was given to configure */
/* Add Timer and UART Driver for this example */
#ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_DRIVER_AMBAPP_GAISLER_GPTIMER
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_DRIVER_AMBAPP_GAISLER_APBUART
#endif
#endif
#include <drvmgr/drvmgr.h>
#include <drvmgr/drvmgr_confdefs.h>
int task_1_waiting_second= 1;
int task_3_waiting_second= 1;
int task_4_waiting_second= 1;
rtems_task_priority task_1_priority=75;
rtems_task_priority task_2_priority=76; //compression task
rtems_task_priority task_3_priority=75;
rtems_task_priority task_4_priority=75;
uint32_t ticks_per_second;
//compression and decompression
#include "Zlib/ZlibCompressionLibrary.h"
#define BASE_BUFFER_BYTE_SIZE (1024*360)
#define COMPRESSING_BUFFER_BYTE_SIZE (BASE_BUFFER_BYTE_SIZE*2)
Bytef base_buffer[BASE_BUFFER_BYTE_SIZE+1024];
Bytef compression_buffer[COMPRESSING_BUFFER_BYTE_SIZE];
Bytef decompression_buffer[COMPRESSING_BUFFER_BYTE_SIZE];
static inline uint32_t get_ticks_per_second( void ){
rtems_interval ticks_per_second;
(void) rtems_clock_get( RTEMS_CLOCK_GET_TICKS_PER_SECOND, &ticks_per_second );
return ticks_per_second;
rtems_task Init(rtems_task_argument argument){
srand(time(NULL));
rtems_status_code status;
rtems_time_of_day time;
time.year = 1988;
time.month = 12;
time.day = 31;
time.hour = 9;
time.minute = 0;
time.second = 0;
time.ticks = 0;
status = rtems_clock_set( &time );
Task_name[ 1 ] = rtems_build_name( 'T', 'A', '1', ' ' );
Task_name[ 2 ] = rtems_build_name( 'T', 'A', '2', ' ' );
Task_name[ 3 ] = rtems_build_name( 'T', 'A', '3', ' ' );
Task_name[ 4 ] = rtems_build_name( 'T', 'A', '4', ' ' );
status = rtems_task_create(
Task_name[ 1 ],
task_1_priority,
RTEMS_MINIMUM_STACK_SIZE * 2,
RTEMS_DEFAULT_MODES,
RTEMS_DEFAULT_ATTRIBUTES,
&Task_id[ 1 ]
Task_name[ 2 ],
task_2_priority,
&Task_id[ 2 ]
Task_name[ 3 ],
task_3_priority,
&Task_id[ 3 ]
Task_name[ 4 ],
task_4_priority,
&Task_id[ 4]
ticks_per_second=get_ticks_per_second();
status = rtems_task_start( Task_id[ 1 ], task_1, 1 );
status = rtems_task_start( Task_id[ 2 ], task_2, 2 );
status = rtems_task_start( Task_id[ 3 ], task_3, 3 );
status = rtems_task_start( Task_id[ 4 ], task_4, 4 );
status = rtems_task_delete( RTEMS_SELF );
//Functions
void create_compression_buffer(){
int i=0;
int max=BASE_BUFFER_BYTE_SIZE;
for(i=0;i<max;i=i+1)
base_buffer[i]=rand();
rtems_task task_1(rtems_task_argument unused){
struct timespec current_time;
while(true){
while(true){
rtems_task_wake_after(task_1_waiting_second * ticks_per_second );
clock_gettime(CLOCK_REALTIME,
¤t_time);
printf( "%s%i%s%i%s",
"\n TASK 1-> ",
(int)current_time.tv_sec,
"s ",
(int)current_time.tv_nsec/1000000,
"ms\n");
rtems_task task_2(rtems_task_argument unused){
while(true){
¤t_time);
"\n TASK 2 COMPRESSING AND UNCOMPRESSING STARTS-> ",
"s ",
"ms\n");
memset(compression_buffer,0,COMPRESSING_BUFFER_BYTE_SIZE);
memset(decompression_buffer,0,COMPRESSING_BUFFER_BYTE_SIZE);
uLongf compressed_byte_size=COMPRESSING_BUFFER_BYTE_SIZE;
if (zlib_compress (compression_buffer,
&compressed_byte_size,
base_buffer,
BASE_BUFFER_BYTE_SIZE)!=0){
printf( "\nERROR compressing\n" );
break;
uLong uncompressed_byte_size=COMPRESSING_BUFFER_BYTE_SIZE;
if (zlib_decompress (decompression_buffer,
&uncompressed_byte_size,
compression_buffer,
compressed_byte_size)!=0){
printf( "\nERROR decompressing\n" );
break;
¤t_time);
"\n TASK 2 COMPRESSING AND UNCOMPRESSING ENDS-> ",
"s ",
"ms\n");
rtems_task task_3(rtems_task_argument unused){
while(true){
rtems_task_wake_after(task_3_waiting_second * ticks_per_second );
¤t_time);
"\n TASK 3-> ",
"s ",
"ms\n");
rtems_task task_4(rtems_task_argument unused){
while(true){
rtems_task_wake_after(task_4_waiting_second * ticks_per_second );
¤t_time);
"\n TASK 4-> ",
"s ",
"ms\n");
