RTEMS - sparc/leon3 BSP configure script error
Mon Jan 19 16:54:44 UTC 2015
On 1/19/2015 10:22 AM, Gedare Bloom wrote:
> Please keep this on the list where others may help.
> You should look at config.status for more info about what may have failed.
You mention gcc 4.9.2 but RTEMS 4.10 used gcc 4.4.7. I doubt Gaisler has
pushed the tools past that.
You need to match the autoconf, automake, and other tools versions or
it won't work.
The compiler is failing to link a simple program during the configure probe.
Try compiling this by hand:
int main() {return 0;}
sparc-rtems4.10-gcc main.c
That is more or less what is failing at this point.
--joel
> On Mon, Jan 19, 2015 at 11:11 AM, Francois ARSENAULT
> <Francois.Arsenault at mdacorporation.com> wrote:
>> Hello,
>> I have corrected the path to the cross-compiler and now the “configure” script should find the compiler (see the “which” command below).
>> $ which sparc-rtems4.10-
>>    sparc-rtems4.10-addr2line.exe  sparc-rtems4.10-g++.exe        sparc-rtems4.10-gprof.exe      sparc-rtems4.10-readelf.exe
>>    sparc-rtems4.10-ar.exe         sparc-rtems4.10-gcc.exe        sparc-rtems4.10-ld.exe         sparc-rtems4.10-size.exe
>>    sparc-rtems4.10-as.exe         sparc-rtems4.10-gcc-4.3.3.exe  sparc-rtems4.10-nm.exe         sparc-rtems4.10-strings.exe
>>    sparc-rtems4.10-c++.exe        sparc-rtems4.10-gccbug         sparc-rtems4.10-objcopy.exe    sparc-rtems4.10-strip.exe
>>    sparc-rtems4.10-c++filt.exe    sparc-rtems4.10-gcov.exe       sparc-rtems4.10-objdump.exe
>>    sparc-rtems4.10-cpp.exe        sparc-rtems4.10-gdb.exe        sparc-rtems4.10-ranlib.exe
>> Note: the cross-compiler came from Gaisler. We’ve used it in another project.
>> Looking at the ./configure error:
>>    checking whether to enable maintainer-specific portions of Makefiles... no
>>    checking for i686-pc-cygwin-gcc... i686-pc-cygwin-gcc
>>    checking whether the C compiler works... no
>>    configure: error: in `/cygdrive/c/COLKa/src/rtems-4.10.2/rtems_build/tools/build':
>>    configure: error: C compiler cannot create executables
>>    See `config.log' for more details
>>    configure: error: /bin/sh '/cygdrive/c/COLKa/src/rtems-4.10.2/tools/build/configure' failed for tools/build
>> It seems that there is an error in the …/build/tools/configure script.
>> Attached to this email, the “config.log” and the …/build/tools/configure script  files.
>> The “config.log” file shows an error in tools/build/configure/configure:4454.
>> In tools/build/configure/configure:4454, this line is a blank line!!!
>> I am not sure what is wrong here…
>> Any suggestion?
>> Thanks,
>> Francois
>> -----Original Message-----
>> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of Gedare Bloom
>> Sent: January-16-15 3:33 PM
>> To: Francois ARSENAULT
>> Cc: users at rtems.org
>> Subject: Re: RTEMS - sparc/leon3 BSP configure script error
>> On Fri, Jan 16, 2015 at 3:29 PM, Francois ARSENAULT <Francois.Arsenault at mdacorporation.com> wrote:
>>> Thanks for your quick answer,
>>> It works better by doing the ./bootstrap  before the configuration. The following is the steps to re-build RTEMS so far...
>>>    rm -fr rtems-4.10.2
>>>    tar xjvf rtems-4.10.2.tar.bz2
>>>    cd rtems-4.10.2/
>>>    ./bootstrap -p
>>>    ./bootstrap
>>>    mkdir rtems_build
>>>    cd rtems_build
>>>    /cygdrive/c/COLKa/src/rtems-4.10.2/configure
>>> --target=sparc-rtems4.10 --enable-posix --disable-networking
>>> --disable-cxx --enable-rtemsbsp=leon3 --prefix=/cygdrive/c/COLKa/src
>>> But the configure still given this error (see the note below for the complete command output):
>>> tools/build
>> You need to have a working toolchain for RTEMS, which will include the sparc-rtems4.10-gcc and all the binutils e.g. sparc-rtems4.10-as, sparc-rtems4.10-ld, and so on. I guess you can probably find what you need under ftp://ftp.rtems.org/pub/rtems/cygwin/4.10/i686/
>> -Gedare
>>> I have the cc and the gcc defined (gcc version 4.9.2) What can be
>>> missing?
>>> Thanks,
>>> Francois
>>> NOTE: this is the configuration command detail output:
>>> ---------------- $ /cygdrive/c/COLKa/src/rtems-4.10.2/configure
>>> --disable-cxx --en
>>> able-rtemsbsp=leon3 --prefix=/cygdrive/c/COLKa/src checking for
>>> gmake... no checking for make... make checking for RTEMS Version...
>>> 4.10.2 checking build system type... i686-pc-cygwin checking host
>>> system type... i686-pc-cygwin checking target system type...
>>> sparc-unknown-rtems4.10 checking for a BSD-compatible install...
>>> /usr/bin/install -c checking whether build environment is sane... yes
>>> checking for a thread-safe mkdir -p... /usr/bin/mkdir -p checking for
>>> gawk... gawk checking whether make sets $(MAKE)... yes checking
>>> whether make supports nested variables... yes checking whether to
>>> enable maintainer-specific portions of Makefiles... no checking that
>>> generated files are newer than configure... done
>>> configure: creating ./config.status
>>> configure: configuring in ./tools/build
>>> configure: running /bin/sh
>>> '/cygdrive/c/COLKa/src/rtems-4.10.2/tools/build/configure' '--prefix=/cygdrive/c/COLKa/src' '--host= d=i686-pc-cygwin'  '--enable-posix' '--disable-networking' '--disable-cxx' '--enable-rtemsbsp=leon3' '--target=sparc-rtems4.10'
>>> ll' '--srcdir=/cygdrive/c/COLKa/src/rtems-4.10.2/tools/build'
>>> checking for gmake... no
>>> checking for RTEMS Version... 4.10.2
>>> checking build system type... i686-pc-cygwin checking host system
>>> type... i686-pc-cygwin checking for a BSD-compatible install...
>>> enable maintainer-specific portions of Makefiles... no checking for
>>> i686-pc-cygwin-gcc... i686-pc-cygwin-gcc checking whether the C
>>> configure: error: C compiler cannot create executables See
>>> tools/build
>>> Of Gedare Bloom
>>> Sent: January-16-15 9:41 AM
>>> Cc: devel at rtems.org
>>> On Fri, Jan 16, 2015 at 7:57 AM, Francois ARSENAULT <Francois.Arsenault at mdacorporation.com> wrote:
>>>> Hello,
>>>> I am new to RTEMS and I want to build a RTEMS application for the
>>>> sparc/leon3 BSP.
>>>> For start, I just want to compile/build RTEMS as is without any
>>>> modification.
>>>> I have the following issue: when executed, the “configure” script
>>>> generates this error:
>>>> ../../configure --target=sparc-rtems
>>>> --prefix=/cygdrive/c/COLKa/src/rtems-4.10.2
>>>> ../../configure: line 1779: syntax error near unexpected token `.'
>>>> ../../configure: line 1779: `RTEMS_TOP(.)'
>>>> Here are the details of the host/target and build commands
>>>> 1) The host is Windows7/Cygwin-32bits
>>>> 2) The RTEMS version is rtems-4.10.2.tar.bz2 (downloaded from
>>>> http://git.rtems.org/rtems/)
>>>> 3) Build commands:
>>>> cd rtems-4.10.2
>>>> ln -s /bin/gcc.exe /bin/cc.exe
>>>> export
>>>> PATH=/cygdrive/c/opt/sparc-elf-4.4.2-mingw/bin:/cygdrive/c/opt/rtems-
>>>> 4
>>>> .10-mingw/bin:${PATH}
>>>> aclocal-1.11
>>>> autoscan-2.69
>>>> autoconf-2.69
>>>> automake-1.11 --add-missing
>>>> cd tools/build
>>>> ../../configure -target=sparc-rtems
>>> Usually you need to specify the version in the target, e.g.
>>> I'm not familiar with the cygwin build process though.
>>>> THIS COMMAND GENERATES THE FOLLOWING ERRORS:
>>> Maybe try to re-run bootstrap in the rtems directory.
>>>> It seems that “RTEMS_TOP” is not defined.
>>>> I have also tried a RTEMS Gaisler distribution
>>>> (rtems-4.8-1.1.2-src.tar.bz2) using  a Linux/Ubuntu host and I have the same error.
>>>> I have also try different autoconf and automake versions and I have
>>>> the same error.
>>>> How can I fix this issue?
>>>> Thanks,
>>>> Francois Arsenault
>>>> Software Engineer
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
> users mailing list
> users at rtems.org
