Beaglebone Bootloader
Wed Jul 1 13:15:44 UTC 2015
On June 29, 2015 6:08:48 PM CDT, Ben Gras <beng at shrike-systems.com> wrote:
>I added BSP_RESET_BOARD_AT_EXIT to bsp.h. (Joel told me it's not
>supposed to be there.) That causes the application to reset once it
>exits. The purpose is to run the tests in qemu in an automated way, as
>qemu can be told to exit once the VM resets.
>That behaviour should not be bsp-default I admit.
There is a macro invoked from configure.ac which can take three arguments. One of them controls the default for reset on exit, another controls printing a message about pursuing a key before reset. Look at another bsp for an example. Pc386 should use it.
>On Tue, Jun 30, 2015 at 12:56 AM, Angelo Fraietta
><newsgroups at smartcontroller.com.au> wrote:
>> Thanks for that. That clears whole thing up.
>> On Tue, Jun 30, 2015 at 1:04 AM, Cláudio Silva
><claudiodcsilva at gmail.com>
>> wrote:
>>> Hello Angelo,
>>> If I use an unaltered hello world example, I get the same behaviour
>as you
>>> in the hello world execution. There is an exit(0) in the end of the
>hello
>>> world example that causes a reboot.If you don't want to reboot you
>need to
>>> replace it with an infinite loop. That is why my example doesn't do
>it.
>>> Best Regards,
>>> Cláudio
>>> On Sun, Jun 28, 2015 at 11:54 PM Angelo Fraietta
>>>> This worked and loaded successfully with tftp,
>>>> Furthermore, I used the script you had to convert the RTEMS exe to
>a
>>>> bootable image and that also worked. However, there was a
>difference in that
>>>> in your exe, when "hello world" finished the beagle halted,
>however, on the
>>>> exe generated on my system, the beagle rebooted at the end of the
>program.
>>>> Also tried it with ticker and the program ran and then rebooted
>when the app
>>>> finished. Would you be able to send me the RTEMS exe (before you
>convert to
>>>> bootable image) of the hello program so I can see whether the
>rebooting is
>>>> caused by the script that converts to a bootable image or whether
>it is in
>>>> the code generation by compiler.
>>>> Thanks for your help in this.
>>>> On Thu, Jun 25, 2015 at 2:07 AM, Cláudio Silva
>>>> wrote:
>>>>> Hi Angelo,
>>>>> Attached to this e-mail you will find an executable in .img format
>that
>>>>> I can boot through TFTP in the BBB.
>>>>> Here are the commands to boot Linux in the uboot command line if
>your
>>>>> uEnv gets corrupted again:
>>>>> https://gist.github.com/cdcs/5ebf5e6ee59746657721
>>>>> Best Regards,
>>>>> Cláudio
>>>>> On Wed, Jun 24, 2015 at 4:27 AM Angelo Fraietta
>>>>>> I got back to my defaule beagle by reflashing. However, can
>someone
>>>>>> please email me a known working image (say hello) that can be
>loaded (and
>>>>>> preferably tested) by tftp. I need to eliminate whether it is the
>executable
>>>>>> generated by me or something else.
>>>>>> Thanks
>>>>>> On Wed, Jun 24, 2015 at 8:40 AM, Angelo Fraietta
>>>>>>> My image is not loading.
>>>>>>> U-Boot SPL 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
>>>>>>> reading args
>>>>>>> spl_load_image_fat_os: error reading image args, err - -1
>>>>>>> reading u-boot.img
>>>>>>> reading u-boot.img
>>>>>>> U-Boot 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
>>>>>>> I2C:   ready
>>>>>>> DRAM:  512 MiB
>>>>>>> NAND:  0 MiB
>>>>>>> MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
>>>>>>> *** Warning - readenv() failed, using default environment
>>>>>>> Net:   <ethaddr> not set. Validating first E-fuse MAC
>>>>>>> cpsw, usb_ether
>>>>>>> Hit any key to stop autoboot:  0
>>>>>>> gpio: pin 53 (gpio 53) value is 1
>>>>>>> Card did not respond to voltage select!
>>>>>>> mmc0(part 0) is current device
>>>>>>> gpio: pin 56 (gpio 56) value is 0
>>>>>>> gpio: pin 55 (gpio 55) value is 0
>>>>>>> gpio: pin 54 (gpio 54) value is 0
>>>>>>> mmc1(part 0) is current device
>>>>>>> gpio: pin 54 (gpio 54) value is 1
>>>>>>> SD/MMC found on device 1
>>>>>>> reading uEnv.txt
>>>>>>> 426 bytes read in 4 ms (103.5 KiB/s)
>>>>>>> gpio: pin 55 (gpio 55) value is 1
>>>>>>> Loaded environment from uEnv.txt
>>>>>>> Importing environment from mmc ...
>>>>>>> Checking if uenvcmd is set ...
>>>>>>> gpio: pin 56 (gpio 56) value is 1
>>>>>>> Running uenvcmd ...
>>>>>>> cpsw Waiting for PHY auto negotiation to complete. done
>>>>>>> link up on port 0, speed 100, full duplex
>>>>>>> Using cpsw device
>>>>>>> TFTP from server 192.168.0.25; our IP address is 192.168.0.53
>>>>>>> Filename '/hello'.
>>>>>>> Load address: 0x81000000
>>>>>>> Loading:
>>>>>>>          4.9 MiB/s
>>>>>>> done
>>>>>>> Bytes transferred = 33554432 (2000000 hex)
>>>>>>> Wrong Image Format for bootm command
>>>>>>> ERROR: can't get kernel image!
>>>>>>> uenvcmd was not defined in uEnv.txt ...
>>>>>>> Booting from nand ...
>>>>>>> no devices available
>>>>>>> Bad Linux ARM zImage magic!
>>>>>>> U-Boot#
>>>>>>> It would not load the image. So I think my image is bad. Can
>someone
>>>>>>> email me the image for the hello example for beagle already
>>>>>>> I modified the uEnv.txt on the device. Now, however, I have a
>beagle
>>>>>>> that is in the uBoot menu and I can't change the eUenv,txt
>because it will
>>>>>>> not how up as a drive because it is not booted into linux.
>>>>>>> How do I get back to beagle linux from u-boot prompt?
>>>>>>> Thanks
>>>>>>> On Tue, Jun 23, 2015 at 6:44 PM, Cláudio Silva
>>>>>>> <claudiodcsilva at gmail.com> wrote:
>>>>>>>> Hello Angelo,
>>>>>>>> I am using the following script snippet to generate a u-boot
>bootable
>>>>>>>> image from an RTEMS .exe:
>>>>>>>> https://gist.github.com/cdcs/0c789e9aae9e79200da5
>>>>>>>> It essentially follows the steps described in Ben's README.
>>>>>>>> If you are using application=/TICKER in the script, it will try
>to
>>>>>>>> load something called TICKER from the tftp root (without any
>extension).
>>>>>>>> Did you try with the u-boot that comes preloaded in the BBB?
>>>>>>>> You can just try boot the linux version provided in the BBB's
>emmc
>>>>>>>> and then change the uEnv.txt ("/boot/uboot/uEnv.txt") to your
>tftp version
>>>>>>>> of uEnv. You shouldn't need the sdcard.
>>>>>>>> Best Regards,
>>>>>>>> Cláudio
>>>>>>>> On Tue, Jun 23, 2015 at 5:59 AM Angelo Fraietta
>>>>>>>>> If it is any help. this is the configuration on my SDCard that
>loads
>>>>>>>>> debian linux from SDCard.
>>>>>>>>> ##Video: Uncomment to override:
>>>>>>>>> ##see:
>https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Documentation/fb/modedb.txt
>>>>>>>>> #kms_force_mode=video=HDMI-A-1:1024x768 at 60e
>>>>>>>>> ##Enable systemd
>>>>>>>>> systemd=quiet init=/lib/systemd/systemd
>>>>>>>>> ##BeagleBone Cape Overrides
>>>>>>>>> ##BeagleBone Black:
>>>>>>>>> ##Disable HDMI/eMMC
>#optargs=capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN,BB-BONE-EMMC-2G
>>>>>>>>> ##Disable HDMI
>>>>>>>>> ##WIP: v3.13+ capes..
>>>>>>>>> #cape=lcd4-01
>>>>>>>>> #cape=
>>>>>>>>> ##note: the eMMC flasher script relies on the next line
>>>>>>>>> mmcroot=UUID=8f529ad7-82d1-4d8e-91dc-31e9e2080813 ro
>>>>>>>>> mmcrootfstype=ext4 rootwait fixrtc
>>>>>>>>> ##These are needed to be compliant with Angstrom's 2013.06.20
>>>>>>>>> u-boot.
>>>>>>>>> console=ttyO0,115200n8
>>>>>>>>> kernel_file=zImage
>>>>>>>>> initrd_file=initrd.img
>>>>>>>>> loadaddr=0x82000000
>>>>>>>>> initrd_addr=0x88080000
>>>>>>>>> fdtaddr=0x88000000
>>>>>>>>> initrd_high=0xffffffff
>>>>>>>>> fdt_high=0xffffffff
>>>>>>>>> loadkernel=load mmc ${mmcdev}:${mmcpart} ${loadaddr}
>${kernel_file}
>>>>>>>>> loadinitrd=load mmc ${mmcdev}:${mmcpart} ${initrd_addr}
>>>>>>>>> ${initrd_file}; setenv initrd_size ${filesize}
>>>>>>>>> loadfdt=load mmc ${mmcdev}:${mmcpart} ${fdtaddr}
>/dtbs/${fdtfile}
>>>>>>>>> loadfiles=run loadkernel; run loadinitrd; run loadfdt
>>>>>>>>> mmcargs=setenv bootargs console=tty0 console=${console}
>${optargs}
>>>>>>>>> ${kms_force_mode} root=${mmcroot} rootfstype=${mmcrootfstype}
>${systemd}
>>>>>>>>> uenvcmd=run loadfiles; run mmcargs; bootz ${loadaddr}
>>>>>>>>> ${initrd_addr}:${initrd_size} ${fdtaddr}
>>>>>>>>> On Tue, Jun 23, 2015 at 12:59 PM, Angelo Fraietta
>>>>>>>>>> I can see I missed a step from Ben's tutorial where it
>creates the
>>>>>>>>>> image file.
>>>>>>>>>> I copied the image to tftp and it did not work
>>>>>>>>>> I also tried doing out of Bens tutorial the
>>>>>>>>>> dd if=bone_hello.exe-sdcard.img of=/dev/mmcblk0 bs=4096
>>>>>>>>>> However, nothing was displayed on my monitor and the three
>LEDS
>>>>>>>>>> lit, followed by the light on ethernet port. It did this
>about three times
>>>>>>>>>> and then booted into normal BBB linux. It looked to me like
>it was
>>>>>>>>>> resetting, however, can't be sure.
>>>>>>>>>> Is someone able to email me a working image for BBB so I can
>see it
>>>>>>>>>> that will boot.
>>>>>>>>>> Thanks
>>>>>>>>>> On Tue, Jun 23, 2015 at 8:46 AM, Angelo Fraietta
>>>>>>>>>>> Does not boot.
>>>>>>>>>>> I have u-boot on the SD card. I know it is being called
>because if
>>>>>>>>>>> I disconnect the ethernet, it freezes and does not boot. If
>I remove SDcard
>>>>>>>>>>> and remove ethernet, it boots normally
>>>>>>>>>>> I have tftp on 192.168.0.25
>>>>>>>>>>> My configuration is exactly this
>>>>>>>>>>> ### BBB : Configuration
>>>>>>>>>>> ipaddr=192.168.0.53
>>>>>>>>>>> serverip=192.168.0.25
>>>>>>>>>>> netmask=255.255.255.0
>>>>>>>>>>> ### XKY-OS : Configuration
>>>>>>>>>>> baseaddr=0x81000000
>>>>>>>>>>> application=/TICKER
>>>>>>>>>>> ### Boot BBB from network
>>>>>>>>>>> nfsargs=setenv bootargs console=${console} root=/dev/nfs
>>>>>>>>>>> nfsroot=${serverip}:${rootpath} rw
>>>>>>>>>>> ip=${ipaddr}:${serverip}:${serverip}:${netmask}::eth0:off
>>>>>>>>>>> xkyboot=run nfsargs; tftp ${baseaddr} ${application}; bootm
>>>>>>>>>>> ${baseaddr}
>>>>>>>>>>> uenvcmd=run xkyboot
>>>>>>>>>>> I have copied ticker.exe to root folder
>>>>>>>>>>> I tried
>>>>>>>>>>> application=/TICKER
>>>>>>>>>>> application=/ticker.exe
>>>>>>>>>>> application=/TICKER.EXE
>>>>>>>>>>> Just boots into normal regardless of what I do (except
>removing
>>>>>>>>>>> ethernet with SDCard in). Looking at U-boot in display looks
>the same as
>>>>>>>>>>> though three was no SDcard. How can I freeze screen to read
>what it all
>>>>>>>>>>> says?
>>>>>>>>>>> I tested my tftp server like this
>http://www.gunnalag.com/2013/08/05/how-to-test-tftp-server-from-a-client-system-in-windows/
>>>>>>>>>>> I did
>>>>>>>>>>> tftp -i 1923.168.0.25 get ticker.exe
>>>>>>>>>>> And it worked fine
>>>>>>>>>>> So if I am using ticker.exe, what should application=/TICKER
>be?
>>>>>>>>>>> Is it case sensitive? Does it need .exe at the end? Am I
>supposed to be
>>>>>>>>>>> using ticker.exe?
>>>>>>>>>>> Can someone send me an exe that does load in BBB so I can
>see if
>>>>>>>>>>> it is that loads.
>>>>>>>>>>> Also, I followed tutorial for installing U-boot on an SDCard
>which
>>>>>>>>>>> boots linux from SDCard and that works
>>>>>>>>>>> http://www.armhf.com/boards/beaglebone-black/bbb-sd-install/
>>>>>>>>>>> Any suggestions would be great
>>>>>>>>>>> Thanks
>>>>>>>>>>> On Mon, Jun 22, 2015 at 6:39 PM, Cláudio Silva
>>>>>>>>>>>> Hi Angelo,
>>>>>>>>>>>> xkyboot is just a command name that is executed by uenvcmd;
>you
>>>>>>>>>>>> can name whatever you want. "XKYAPP2" is the executable
>name. It should
>>>>>>>>>>>> placed on the tftp server's root, or otherwise you need to
>provide the full
>>>>>>>>>>>> path to it.
>>>>>>>>>>>> Is your tftp server working correctly? Try to test from a
>tftp
>>>>>>>>>>>> client on Linux.
>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>> Cláudio
>>>>>>>>>>>> On Mon, Jun 22, 2015 at 6:51 AM Angelo Fraietta
>>>>>>>>>>>>> I am using BBB also
>>>>>>>>>>>>> I have had a look at what you have provided
>>>>>>>>>>>>> are XKYAPP2 and xkyboot  your app names?
>>>>>>>>>>>>> Lets say I wanted to boot ticker from tftp server (assume
>my
>>>>>>>>>>>>> tftp server has same ip address as yours)
>>>>>>>>>>>>> I have copied
>development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/samples/ticker/ticker.exe
>>>>>>>>>>>>> to the root of my tftp server
>>>>>>>>>>>>> I am assuming this is entire uEnv.txt What should it look
>like
>>>>>>>>>>>>> (I have provided whole of your file here). Thanks
>>>>>>>>>>>>> ipaddr=192.168.0.202
>>>>>>>>>>>>> baseaddr=0x81000000
>>>>>>>>>>>>> application=/XKYAPP2
>bootm
>>>>>>>>>>>>> ${baseaddr}
>>>>>>>>>>>>> uenvcmd=run xkyboot
>>>>>>>>>>>>> On Fri, Jun 19, 2015 at 6:14 PM, Cláudio Silva
>>>>>>>>>>>>>> You should be able to boot RTEMS through TFTP. At least I
>do it
>>>>>>>>>>>>>> in the BBB, I assume the white version should work as
>well. You just have to
>>>>>>>>>>>>>> change uboot configuration and setup a tftp server.
>>>>>>>>>>>>>> My current uboot configuration is the following:
>>>>>>>>>>>>>> https://gist.github.com/cdcs/76c4dd49c2d574bd68cc
>>>>>>>>>>>>>> Cláudio
>>>>>>>>>>>>>> On Fri, Jun 19, 2015 at 5:57 AM Chris Johns
><chrisj at rtems.org>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>> On 19/06/2015 1:56 pm, Angelo Fraietta wrote:
>>>>>>>>>>>>>>> > Those links I posted -- do any of them work with
>RTEMS?
>>>>>>>>>>>>>>> I do not know. I have no interested uboot. Maybe someone
>else
>>>>>>>>>>>>>>> knows.
>>>>>>>>>>>>>>> Chris
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>> users mailing list
>>>>>>>>>>>>>>> users at rtems.org
>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
>users mailing list
>users at rtems.org
--joel
