Attempting to build an app for Beaglebone
Angelo Fraietta
newsgroups at smartcontroller.com.au
Thu Jul 2 01:27:56 UTC 2015
Thanks - Needed to be first.
However, I modified command to do
CONSOLE_POLLED=1 ../rtems-src/configure --target=arm-rtems4.11
--enable-rtemsbsp=beagleboneblack --enable-tests --prefix=/opt/rtems-4.11
I had to do
make
and then
make install
during the install I got
/bin/mkdir -p '/opt/rtems-4.11/arm-rtems4.11/beagleboneblack/lib'
/usr/bin/install -c -m 644 libnfs.a
( cd '/opt/rtems-4.11/arm-rtems4.11/beagleboneblack/lib' &&
arm-rtems4.11-ranlib libnfs.a )
/bin/bash: line 5: arm-rtems4.11-ranlib: command not found
make[6]: *** [install-project_libLIBRARIES] Error 127
make[6]: Leaving directory
`/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/cpukit/libfs/src/nfsclie
nt'
make[5]: *** [install-am] Error 2
make[5]: Leaving directory
nt'
make[4]: *** [install-recursive] Error 1
make[4]: Leaving directory
`/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/cpukit/libfs'
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory
`/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/cpukit'
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory
`/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory
`/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c'
make: *** [install-recursive] Error 1
however, I ran arm-rtems4.11-ranlib from commandline and it was in the path
angelo at debian:~/development/rtems/b-beagle$ arm-rtems4.11-ranlib
Usage: arm-rtems4.11-ranlib [options] archive
Generate an index to speed access to archives
The options are:
@<file> Read options from <file>
-D Use zero for symbol map timestamp (default)
-U Use an actual symbol map timestamp
-t Update the archive's symbol map timestamp
-h --help Print this help message
-v --version Print version information
arm-rtems4.11-ranlib: supported targets: elf32-littlearm elf32-bigarm
elf32-little elf32-big srec symbolsrec verilog tekhex binary ihex
On Thu, Jul 2, 2015 at 10:09 AM, Ben Gras <beng at shrike-systems.com> wrote:
> That is likely a $PATH problem. Make sure your RTEMS prefix/bin is
> first in your $PATH when you do this.
> Good luck :)
> On Thu, Jul 2, 2015 at 1:51 AM, Angelo Fraietta
> <newsgroups at smartcontroller.com.au> wrote:
> > I thought I would try and rebuild sources again, however, I got an error
> > that autoconf version 2.69 or greater was required when I tried to
> > bootstrap. I don't know why it all passed last time. I am updating my
> > system and after that will try again
> > On Thu, Jul 2, 2015 at 9:25 AM, Angelo Fraietta
> >> I followed Ben's tutorial.
> >> % ../source-builder/sb-set-builder --log=beagle.txt
> >> --prefix=$HOME/development/rtems/4.11 devel/beagle.bset
> >> and
> >> % mkdir b-beagle ; cd b-beagle
> >> % CONSOLE_POLLED=1 ../rtems-src/configure --target=arm-rtems4.11
> >> --enable-rtemsbsp="beagleboneblack beagleboardxm" --enable-tests
> >> % make
> >> I have done a grep for that file and it comes up like this
> >> angelo at debian:~/development$ find -name leaf.cfg
> >> ./rtems/b-beagle/arm-rtems4.11/c/beagleboardxm/make/leaf.cfg
> >> ./rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/make/leaf.cfg
> >> ./rtems/rtems-src/make/leaf.cfg
> >> ./rtems/rtems-src/c/src/make/leaf.cfg
> >> So I decided to do a symlink
> >> root at debian:/opt# ln -s
> >> beagleboneblack/ /opt/rtems-4.11
> >> Now when I go make, I get the error
> >> make: *** No rule to make target `/init.o', needed by `/gpio.exe'.
> Stop.
> >> So it seems that ARCH is not being defined somewhere that it needs to
> be.
> >> So making the symlink is not the solution.
> >> Also, looking at RTEMS doc,
> >> https://docs.rtems.org/doc-current/share/rtems/pdf/started.pdf, it
> said it
> >> was supposed to install to /opt/rtems-4.11 by default, which it did not.
> >> On Thu, Jul 2, 2015 at 6:58 AM, Diego Sanz <dshernan80 at gmail.com>
> wrote:
> >>> One question, this Makefile has been made by you?, or you has used
> >>> another one from an example of building applications?
> >>> What is strange from my point of view is that:
> >>> your "RTEMS_MAKEFILE_PATH:
> /home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/make/"
> >>> includes the last make folder try with:
> /home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack, I
> >>> suppose that that this is where you have installed your RTEMS built for
> >>> architecture arm-rtems4.11, and board beagleboneblack...
> >>> another problem is that you have as a target not found
> >>> /opt/rtems-4.11/make/leaf.cfg, and then is because you have RTEMS
> installed
> >>> in other place, it looks you have installed here:
> >>> /home/angelo/development/rtems/b-beagle/arm-rtems4.11.
> >>> Then
> >>> RTEMS_MAKEFILE_PATH should be the place where RTEMS (after be compiled)
> >>> is installed for your architecture arm and beagleboneblack
> >>> Hope this give you some ide, but if you continue with the problem, take
> >>> as example the example-v2 from the RTEMs repo, to make you a better
> idea
> >>> 2015-06-30 6:45 GMT+02:00 Angelo Fraietta
> >>> <newsgroups at smartcontroller.com.au>:
> >>>> To add a bit more light on what is happening, I added some echo in
> make
> >>>> to find out what the variables are being evaluated as. This is what I
> get
> >>>> RTEMS_ROOT: /opt/rtems-4.11
> >>>> RTEMS_CUSTOM: /opt/rtems-4.11/make/custom/beagleboneblack.cfg
> >>>> On Mon, Jun 29, 2015 at 2:18 PM, Angelo Fraietta
> >>>>> Greetings
> >>>>> I have been able to successfully able to build and run RTEMS samples
> >>>>> using Ben's tutorial at
> http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
> >>>>> with a few mods and am able to run using tftp
> >>>>> However, I am having difficulty using my own make file to build an
> app.
> >>>>> I have added RTEMS_MAKEFILE_PATH to my environment and added
> >>>>> PATH=$PATH:/home/angelo/development/rtems/4.11/bin
> >>>>> When I run my makefile, I get an error
> >>>>> Makefile:41: /opt/rtems-4.11/make/leaf.cfg: No such file or directory
> >>>>> make: *** No rule to make target `/opt/rtems-4.11/make/leaf.cfg'.
> >>>>> Stop.
> >>>>> It looks to me like RTEMS_ROOT is not being set properly (I could be
> >>>>> wrong)
> >>>>> Find below makefile contents
> >>>>> EXEC=gpio.exe
> >>>>> # C source names, if any, go here -- minus the .c
> >>>>> C_PIECES= init
> >>>>> C_FILES=$(C_PIECES:%=%.c)
> >>>>> C_O_FILES=$(C_PIECES:%=${ARCH}/%.o)
> >>>>> # C++ source names, if any, go here -- minus the .cc
> >>>>> CC_PIECES=
> >>>>> CC_FILES=$(CC_PIECES:%=%.cpp)
> >>>>> CC_O_FILES=$(CC_PIECES:%=${ARCH}/%.o)
> >>>>> H_FILES=
> >>>>> # Assembly source names, if any, go here -- minus the .S
> >>>>> S_PIECES=
> >>>>> S_FILES=$(S_PIECES:%=%.S)
> >>>>> S_O_FILES=$(S_FILES:%.S=${ARCH}/%.o)
> >>>>> SRCS=$(C_FILES) $(CC_FILES) $(H_FILES) $(S_FILES)
> >>>>> OBJS=$(C_O_FILES) $(CC_O_FILES) $(S_O_FILES)
> >>>>> PGMS=${ARCH}/$(EXEC) #${ARCH}/xxx-another-one
> >>>>> # List of RTEMS managers to be included in the application goes here.
> >>>>> # Use:
> >>>>> # MANAGERS=all
> >>>>> # to include all RTEMS managers in the application.
> >>>>> MANAGERS=io event message rate_monotonic semaphore timer
> >>>>> include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> >>>>> include $(RTEMS_CUSTOM)
> >>>>> include $(RTEMS_ROOT)/make/leaf.cfg
> >>>>> # (OPTIONAL) Add local stuff here using +=
> >>>>> DEFINES +=
> >>>>> CPPFLAGS +=
> >>>>> XCPPFLAGS +=
> >>>>> CFLAGS +=
> >>>>> # CFLAGS_DEBUG_V are used when the `make debug' target is built.
> >>>>> # To link your application with the non-optimized RTEMS routines,
> >>>>> # uncomment the following line:
> >>>>> # CFLAGS_DEBUG_V += -qrtems_debug
> >>>>> LD_PATHS += #xxx-your-EXTRA-library-paths-go-here, if any
> >>>>> LD_LIBS +=
> >>>>> # Add the following code when attempting to strip down in size
> >>>>> #LDFLAGS += -Wl,'-gc-sections'
> >>>>> # Add your list of files to delete here. The config files
> >>>>> # already know how to delete some stuff, so you may want
> >>>>> # to just run 'make clean' first to see what gets missed.
> >>>>> # 'make clobber' already includes 'make clean'
> >>>>> CLEAN_ADDITIONS +=
> >>>>> CLOBBER_ADDITIONS +=
> >>>>> all: ${ARCH} $(SRCS) $(PGMS)
> >>>>> ${ARCH}/$(EXEC): ${OBJS} ${LINK_FILES}
> >>>>> $(make-cxx-exe)
> >>>>> # Install the program(s), appending _g or _p as appropriate.
> >>>>> # for include files, just use $(INSTALL_CHANGE)
> >>>>> install: all
> >>>>> $(INSTALL_VARIANT) -m 555 ${PGMS} ${PROJECT_RELEASE}/bin
> >>>>> Any ideas?
> >>>>> Thanks
> >>>> _______________________________________________
> >>>> users mailing list
> >>>> users at rtems.org
> >>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20150702/259e167a/attachment-0001.html>
