Hello world Ada-example on RaspberryPi
Hugues Jérôme hugues.jerome at gmail.com
Mon Jul 6 18:05:13 UTC 2015
Hi Jan,
Check this
	https://git.rtems.org/ada-examples/tree/rtems_init.c
I wonder whether this setting is BSP setting or not. If always seen this file there ..
Regards,
Le 6 juil. 2015 à 20:02, Jan Sommer <soja-misc at aries.uberspace.de> a écrit :
> Ok, in rtems_init.c
> #define CONFIGURE_MICROSECONDS_PER_TICK RTEMS_MILLISECONDS_TO_MICROSECONDS(1)
> causes the 2.5s delay to be 25 s. If I set it to
> #define CONFIGURE_MICROSECONDS_PER_TICK RTEMS_MILLISECONDS_TO_MICROSECONDS(10)
> then the delay will be 2.5 s.
> How (or where) is the number of ticks to wait computed when a delay is called in Ada?
> Cheers,
>   Jan
> Am Sonntag, 5. Juli 2015, 23:11:36 schrieb Jan Sommer:
>> Hi,
>> I tried to run the hello_world_ada example on the raspberryPi today and ran into a few issues.
>> First, there was the linking problem for the function _ada_pthread_minimum_stack_size where is that supposed to be defined?
>> There is also an issue with the current Makefile.shared in the top level example-directory. The Makefile of the hello_world program adds a define for the stack size to the CFLAGS and later includes the Makefile.shared. However there CFLAGS is set to "" in the beginning effectively deleting the stack size set previosly. I commented this line as well (don't know if it will have side effects in later examples).
>> The program then linked. Running the program on the Pi worked as well, but with one problem. The Delay of 2.5 s took 25 s. I changed the delay time several times and it always is accurately 10 time the set delay time.
>> I guess there is some clock setting wrong somewhere? Where would I need to correct that?
>> Cheers,
>>   Jan
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
