Interrupt server on BBB
Angelo Fraietta
newsgroups at smartcontroller.com.au
Mon Jul 13 23:36:32 UTC 2015
It may be off track but try increasing your stack size for the tasks.
What you can also try is instead of doing a printk, try blinking one of the
Leds on an interrupt - just removes the printk from equation.
On Mon, Jul 13, 2015 at 10:49 PM, Martin Galvan <
martin.galvan at tallertechnologies.com> wrote:
> Hi everyone! I'm currently trying to use an interrupt server task for
> handling USB interrupts on the Beaglebone Black. Here's the code I'm
> using:
> rtems_interrupt_server_initialize(1, 1500, RTEMS_TIMESLICE | RTEMS_PREEMPT,
> RTEMS_DEFAULT_ATTRIBUTES, NULL);
> rtems_interrupt_server_handler_install(NULL, AM335X_INT_USB1,
> "USB_interrupt",
> RTEMS_INTERRUPT_UNIQUE,
> reinterpret_cast<rtems_interrupt_handler>(USB1HostIntHandler), NULL);
> I checked the return codes of both functions and it's always
> RTEMS_SUCCESSFUL. At the same time I have a separate thread which is
> constantly doing a printk for debugging purposes.
> Right now what happens is that the printk thread runs about 10-15
> times and then the system hangs in the middle of the print. Am I doing
> something wrong?
> Thanks a lot!
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150714/10b3b37b/attachment.html>
