Memory Leak in 'ping' ?
Tue Jul 14 16:06:26 UTC 2015
On Tue, Jul 14, 2015 at 12:00 PM, Isaac Gutekunst
<isaac.gutekunst at vecna.com> wrote:
> We are using 4.11 with
> --enable-networking. Is the libbsd? It is using mbufs, so I'm guessing so.
This is libnetworking, and it should be avoided really, unless it
already works for your board. I'd suggest you switch your effort to
either libbsd or lwip.
libbsd: https://git.rtems.org/rtems-libbsd/
The libbsd is an updated port from freebsd, and if there are drivers
for your boards available in freebsd9+ then this is a good option.
> lwip might be the path of least resistance, especially since I have bare
> metal example for this target using lwip.
Yep.
> We may need full performance, but it's hard to say at this point.
Ideally you can switch over to libbsd if you find lwip is insufficient.
Gedare
> Isaac
> On 07/14/2015 11:49 AM, Gedare Bloom wrote:
>> What version of RTEMS are you using, and what networking stack?
>> For 4.10 there is the libnetworking or port lwip, for 4.11 there is
>> libnetworking, libbsd, and lwip.
>> I'd recommend 4.11 with libbsd or lwip. for a small target, lwip is a
>> good option unless you need full performance which can be hard to
>> squeeze out of lwip.
>> -Gedare
>> On Tue, Jul 14, 2015 at 11:44 AM, Isaac Gutekunst
>>> On 07/14/2015 11:30 AM, Joel Sherrill wrote:
>>>> On 7/14/2015 10:18 AM, Isaac Gutekunst wrote:
>>>>> Hi All,
>>>>> I'm working on a network driver for the STM32F4, and as part of this
>>>>> process wanted to see if the ping command could ping 127.0.0.1 even
>>>>> with
>>>>> an empty driver.
>>>>> It works a few times, and then fails with 'error: no memory'.
>>>>> This target has 192K of RAM. What would be helpful for me is if a
>>>>> couple
>>>>> people tried running ping, and then wkspace, and reporting whether they
>>>>> see memory leaking.
>>>>> I could also be completely off target in my reasoning. Any other ideas
>>>>> about why I'm seeing this behaviour.
>>>> The commands were ported directly from FreeBSD. They ran as processes
>>>> so could not free memory because exit() would clean up. They could also
>>>> get away with leaking since there is more memory.
>>> This makes sense. I'll continue working on the driver and figure out how
>>> to
>>> test it later.
>>>> But I don't see a malloc() in ping.c. So it might be leaking in a called
>>>> method.
>>> I've been looking in cpukit/libmisc/shell/main_ping.c
>>> I've modified it to print the amount of bytes allocated on line 378.
>>> I can't find a corresponding free call, but a few calls freeing 'buf',
>>> which
>>> comes from ipsec_set_policy.
>>>> It is also possible since the test is likely running in unified memory
>>>> mode that it has consumed more memory for network stack buffers and this
>>>> memory failure is really sendto() failing to allocate mbufs.
>>> My network driver is certainly almost empty and probably not allocating
>>> mbfus, since I'm still learning what those are :)
>>> Aside: Besides the Networking supplement, and BSP development guide (and
>>> source code), are there any good resources for learning about how to
>>> create
>>> a network driver for RTEMS? I'm getting a bit caught up in what part of
>>> some
>>> of the existing drivers is RTEMS specific and what is MAC specific.
>>>>> I believe the wkspace command hang is unrelated.
>>>> Hard to guess at this point.
>>>>> Lots more details below:
>>>>> On startup:
>>>>> [/] # wkspace
>>>>> C Program Heap and RTEMS Workspace are the same.
>>>>> Number of free blocks:                               4
>>>>> Largest free block:                              14784
>>>>> Total bytes free:                                14856
>>>>> Number of used blocks:                             119
>>>>> Largest used block:                               7832
>>>>> Total bytes used:                                49952
>>>>> Size of the allocatable area in bytes:           64808
>>>>> Minimum free size ever in bytes:                 13824
>>>>> Maximum number of free blocks ever:                  5
>>>>> Maximum number of blocks searched ever:              5
>>>>> Lifetime number of bytes allocated:              57168
>>>>> Lifetime number of bytes freed:                   7216
>>>>> Total number of searches:                          215
>>>>> Total number of successful allocations:            140
>>>>> Total number of failed allocations:                  0
>>>>> Total number of successful frees:                   21
>>>>> Total number of successful resizes:                  0
>>>>> [/] # ping 127.0.0.1
>>>>> Ping allocating 4536 bytes.
>>>>> PING 127.0.0.1 (127.0.0.1): 56 data bytes
>>>>> 64 bytes from 127.0.0.1: icmp_seq=0 ttl=255 time=0.770 ms
>>>>> 64 bytes from 127.0.0.1: icmp_seq=1 ttl=255 time=0.728 ms
>>>>> 64 bytes from 127.0.0.1: icmp_seq=2 ttl=255 time=0.728 ms
>>>>> 64 bytes from 127.0.0.1: icmp_seq=3 ttl=255 time=0.729 ms
>>>>> 64 bytes from 127.0.0.1: icmp_seq=4 ttl=255 time=0.729 ms
>>>>> --- 127.0.0.1 ping statistics ---
>>>>> 5 packets transmitted, 5 packets received, 0.0% packet loss
>>>>> round-trip min/avg/max/stddev = 0.728/0.737/0.770 ms
>>>>> Note: I added the "Ping allocating %d bytes." printf and modified ping
>>>>> to allocate less memory in rtems_shell_globals_t in the outpackhdr and
>>>>> packet.
>>>>> After running ping once, the wkspace command no longer works and hangs
>>>>> after printing "C Program Heap and RTEMS Workspace are the same."
>>>>> The debugger shows the error as RTEMS_FATAL_SOURCE_EXCEPTION.
>>>>> The dissasembly around the_error show it as inside of
>>>>> Console_Configuration_Ports. I haven't investigated further.
>>>>> 2000110c:   ldr r7, [pc, #700]      ; (0x200013cc
>>>>> <Console_Configuration_Ports+52>)
>>>>> 2000110e:   movs r1, r0
>>>>> 20001110:   asrs r0, r5, #5
>>>>> 20001112:   movs r0, #0
>>>>> 20001114:   ldr r3, [sp, #428]      ; 0x1ac
>>>>> 20001116:   movs r3, r0
>>>>> 20001118:   asrs r0, r5, #5
>>>>> 2000111a:   movs r0, #0
>>>>> 2000111c:    ; <UNDEFINED> instruction: 0xfffdffff
>>>>> 20001120:   ldrh r4, [r0, #16]
>>>>> 20001122:   movs r0, #1
>>>>> 20001124:    ; <UNDEFINED> instruction: 0xf3982000
>>>>> 20001128:   lsls r4, r3, #16
>>>>> 2000112a:   movs r0, r0
>>>>> 2000112c:    ; <UNDEFINED> instruction: 0xf3982000
>>>>> 20001130:   ldrb r4, [r3, #22]
>>>>> 20001132:   ands r2, r0
>>>>> 20001134:   strb r5, [r6, #11]This target has 192K of RAM. What would
>>>>> be
>>>>> helpful for me is if a couple people tried running ping, and then
>>>>> wkspace, and reporting whether they see memory leaking.
>>> Isaac Gutekunst
>>> Embedded Systems Software Engineer
>>> www.vecna.com
>>> Cambridge Research Laboratory
>>> Vecna Technologies, Inc.
>>> 36 Cambridge Park Drive
>>> Cambridge, MA 02140
>>> Office: (617) 864-0636 x3069
>>> Fax: (617) 864-0638
>>> http://vecna.com
>>> Better Technology, Better World (TM)
>>> The contents of this message may be privileged and confidential.
>>> Therefore,
>>> if this message has been received in error,
>>> please delete it without reading it. Your receipt of this message is not
>>> intended to waive any applicable privilege.
>>> Please do not disseminate this message without the permission of the
>>> author.
>>>>> 20001136:   movs r4, r0
>>>>> 20001138:   vrev64.32 d18, d1
>>>>> 2000113c:   str r6, [sp, #352]      ; 0x160
>>>>> 2000113e:   movs r0, #1
>>>>> 20001140:   str r6, [sp, #256]      ; 0x100
>>>>> 20001142:   movs r0, #1
>>>>> Thanks,
>>>>> Isaac Gutekunst
>>>>> www.vecna.com
>>>>> _______________________________________________
>>>>> users mailing list
>>>>> users at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/users
>>> users mailing list
>>> users at rtems.org
