Hello_via_task Ada example on Rapberry
Jan Sommer soja-misc at aries.uberspace.de
Wed Jul 15 21:23:12 UTC 2015
I placed the debug statements in the files you suggested, rebuild rtems and compiled both examples: hello_world_ada (which works) and hello_via_task (which hangs).
The output from generated by workspace_allocate are basically the same they only differ in the addresses they print, but the size and order of the allocation are the same, except that for the hello_via_task example one additional allocation is called at the very end.
However several allocations seem to have failed, especially in the beginning (but in both examples). I don't know if this is a severe failure, or if it is expected to happen. Nevertheless the output I get the hello_via_task example is the following (as said before the output for the hello_ada example is the same except for the last allocation):
Workspace_Allocate_or_fatal_error(24) from 44A50/0 -> 10ED78
Workspace_Allocate_or_fatal_error(112) from 4161C/0 -> 10EDB8
Workspace_Allocate_or_fatal_error(28) from 41660/0 -> 10EE50
Workspace_Free(0) from 4173C/0
Workspace_Allocate_or_fatal_error(1304) from 4161C/0 -> 10EE90
Workspace_Allocate_or_fatal_error(24) from 41660/0 -> 10F3D0
Workspace_Allocate_or_fatal_error(26080) from 4161C/0 -> 10F410
Workspace_Allocate_or_fatal_error(100) from 41660/0 -> 115A18
Workspace_Allocate(480) from 417CC/0 -> 115AA0
Workspace_Allocate(52) from 417E0/0 -> 115CA8
Workspace_Allocate(736) from 417CC/0 -> 115D00
Workspace_Allocate(52) from 417E0/0 -> 116008
Workspace_Allocate_or_fatal_error(1512) from 4161C/0 -> 116060
Workspace_Allocate_or_fatal_error(128) from 41660/0 -> 116670
Workspace_Allocate(384) from 417CC/0 -> 116718
Workspace_Allocate(52) from 417E0/0 -> 1168C0
Workspace_Allocate(1856) from 417CC/0 -> 116918
Workspace_Allocate(52) from 417E0/0 -> 117080
Workspace_Allocate(224) from 417CC/0 -> 1170D8
Workspace_Allocate(52) from 417E0/0 -> 1171E0
Workspace_Allocate(1664) from 417CC/0 -> 117238
Workspace_Allocate(52) from 417E0/0 -> 1178E0
Workspace_Allocate(416) from 417CC/0 -> 117938
Workspace_Allocate(52) from 417E0/0 -> 117B00
Workspace_Allocate(180) from 417CC/0 -> 117B58
Workspace_Allocate(56) from 417E0/0 -> 117C30
Workspace_Allocate_or_fatal_error(288) from 402EC/0 -> 117C90
Workspace_Allocate(36512) from 417CC/0 -> 117DD8
Workspace_Allocate(132) from 417E0/0 -> 120CA0
Workspace_Allocate(1232) from 417CC/0 -> 120D48
Workspace_Allocate(132) from 417E0/0 -> 121240
Workspace_Allocate(2128) from 417CC/0 -> 1212E8
Workspace_Allocate(172) from 417E0/0 -> 121B60
Workspace_Allocate(960) from 417CC/0 -> 121C30
Workspace_Allocate(52) from 417E0/0 -> 122018
Workspace_Allocate(192) from 417CC/0 -> 122070
Workspace_Allocate(52) from 417E0/0 -> 122158
Workspace_Allocate(480) from 417CC/0 -> 1221B0
Workspace_Allocate(52) from 417E0/0 -> 1223B8
Workspace_Allocate(928) from 417CC/0 -> 122410
Workspace_Allocate(52) from 417E0/0 -> 1227D8
Workspace_Allocate(384) from 417CC/0 -> 122830
Workspace_Allocate(52) from 417E0/0 -> 1229D8
Workspace_Allocate(384) from 417CC/0 -> 122A30
Workspace_Allocate(52) from 417E0/0 -> 122BD8
Workspace_Allocate(256) from 417CC/0 -> 122C30
Workspace_Allocate(52) from 417E0/0 -> 122D58
Workspace_Allocate(4096) from 4448C/0 -> 122DB0
Workspace_Allocate(8192) from 4448C/0 -> 124000
Workspace_Allocate(102400) from 4448C/0 -> 126398
Workspace_Allocate(16384) from 4448C/0 -> 142CF8
*** GNAT/RTEMS Hello World Test ***
Welcome to the World of Lady Ada
Initiating 2.5 second delay
Am Dienstag, 14. Juli 2015, 15:26:01 schrieb Joel Sherrill:
> On 7/14/2015 3:13 PM, Jan Sommer wrote:
> > One question. If the Ada main thread is created using pthread in the beginning and then creates new task
> >(in Ada), do these tasks take their stack from the Ada main thread or do they get their own stack
> >allocated from available memory?
> Ada tasks are just pthreads and their stack comes from the workspace.
> One option is some selectively placed debug statements.
> + score/src/objectallocate.c already has a debug section you
> can turn on to print on object allocation failure. This would
> let you know if you ran out of pthreads, semaphores, etc.
> + libcsupport/src/malloc.c for a NULL being returned.
> + score/src/wkspace.c - _Workspace_Allocate for a NULL being
> returned. There is a printk in here which prints every allocation
> and the return addresses.
> If it is a resource issue, that should help narrow it down.
> > Am Sonntag, 12. Juli 2015, 18:31:57 schrieb Jan Sommer:
> >> Am Sonntag, 12. Juli 2015, 10:26:56 schrieb Joel Sherrill:
> >>> Just to make sure we are on the same page, what gcc version?
> >> gcc 4.9.2
> >>> It sounds like the number of resources configured might be off. Can you try unlimited objects and unified workspace? They are CONFIGURE_ parameters.
> >> I added
> >> #define CONFIGURE_UNIFIED_WORK_AREAS
> >> #define CONFIGURE_UNLIMITED_OBJECTS
> >> to the rtems-init.c of the Ada examples I hope this does not conflict with the other defines like
> >> #define CONFIGURE_MAXIMUM_TASKS                         20
> >> #define CONFIGURE_MAXIMUM_SEMAPHORES          20
> >> #define CONFIGURE_GNAT_RTEMS
> >> #define CONFIGURE_MAXIMUM_ADA_TASKS      20
> >> #if !defined(CONFIGURE_MAXIMUM_FAKE_ADA_TASKS)
> >>    #define CONFIGURE_MAXIMUM_FAKE_ADA_TASKS 0
> >> #endif
> >> #if !defined(ADA_APPLICATION_NEEDS_EXTRA_MEMORY)
> >>    #define ADA_APPLICATION_NEEDS_EXTRA_MEMORY 0
> >> #endif
> >> /* Account for any extra task stack size */
> >> #define CONFIGURE_MEMORY_OVERHEAD \
> >>    (ADA_APPLICATION_NEEDS_EXTRA_MEMORY + GNAT_MAIN_STACKSPACE)
> >> Still the task hangs after it calls the delay.
> >> Best regards,
> >>    Jan
> >> _______________________________________________
> >> users mailing list
> >> users at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> > users at rtems.org
