net-snmp using RSB
Adit Sahasrabudhe asahasra at fb.com
Fri Jul 17 21:14:54 UTC 2015
Thank you for explaining that Chris. We could see the package being built
into a tmp directory, but it would just get deleted, so that clarifies it.
One more question though. We modified the source builder python, so that
it doesn¹t delete the built files. We then manually installed those files
into our RTEMS installation (under our BSP). It¹s still unclear how to use
this library. The example code on the package page seems to indicate that
a binary is meant to be generated and then Untar¹d into a memory location.
If this is correct, where does that binary come from? There are a couple
of extern int declarations showing the start and end addresses of memory
for that extraction. Do we need to modify our linker scripts to define
those locations?
Adit
On 7/17/15, 1:07 AM, "users on behalf of Chris Johns"
<users-bounces at rtems.org on behalf of chrisj at rtems.org> wrote:
>On 17/07/2015 9:05 am, Chris Johns wrote:
>>> Any idea what I may have missed? I wanted to attach my net-snmp build
>>> log, but the file is too big. Let me know if it might be helpful.
>> The install prefix the package is using seems wrong. It is putting the
>> package under the build host under the prefix you provide. I will need
>> to take a closer to look at how the package installs to see what I can
>>do.
>I have a taken a closer look and the issue is a little more complex that
>I thought. The NetSNMP build uses --host and --build, which is normal,
>however this tripped logic in the RSB which made it think it was a
>Canadian cross (Cxc) build so it did not install the package once built.
>Cxc builds do not install because the resulting packages are for a
>different host and often the prefix used is not writable on the build
>host. Fixing NetSNMP broken the Cxc build of the tools. I am working
>through the issues and have NetSNMP building and the Cxc is still not
>working.
>Joel, this needs to be fixed for the branch.
>Chris
>_______________________________________________
>users mailing list
>users at rtems.org
>https://urldefense.proofpoint.com/v1/url?u=http://lists.rtems.org/mailman/
>listinfo/users&k=ZVNjlDMF0FElm4dQtryO4A%3D%3D%0A&r=akrirLnAihUFmXpddZqcJw%
>3D%3D%0A&m=hDnAXnyjE9DoqMLdRWBk7APhvTWioVoehrezEoL4t4I%3D%0A&s=c945722743a
>eb6de82782930b56027fb61e443a586f173d65ac6d4006c9c9d53
