net-snmp using RSB
Adit Sahasrabudhe asahasra at fb.com
Mon Jul 20 16:22:26 UTC 2015
So it still seems to be trying to perform a Canadian cross build, instead
of a standard cross build. Here is the output I get:
[dev at centos6: rtems]$ ../source-builder/sb-set-builder --log=log_snmp.txt
--prefix=~/development/rtems/4.11/ --host=arm-rtems4.11
--rtems-bsp=arm/altcycv_devkit 4.11/net-mgmt/net-snmp
RTEMS Source Builder - Set Builder, v4.11.0
Build Set: 4.11/net-mgmt/net-snmp
config: net-mgmt/net-snmp-5.7.2.1-1.cfg
error: config error: rtems-bsp.cfg:20: Canadian cross building for BSP is
not supported.
Build FAILED
Build Set: Time 0:00:00.003678
Build FAILED
Adit
On 7/19/15, 9:07 PM, "users on behalf of Chris Johns"
<users-bounces at rtems.org on behalf of chrisj at rtems.org> wrote:
>On 18/07/2015 9:52 am, Chris Johns wrote:
>> On 18/07/2015 7:14 am, Adit Sahasrabudhe wrote:
>>> Thank you for explaining that Chris. We could see the package being
>>>built
>>> into a tmp directory, but it would just get deleted, so that clarifies
>>>it.
>> I am still working on a fix. I have created a ticket
>>(https://urldefense.proofpoint.com/v1/url?u=https://devel.rtems.org/ticke
>>t/2374%23ticket&k=ZVNjlDMF0FElm4dQtryO4A%3D%3D%0A&r=akrirLnAihUFmXpddZqcJ
>>w%3D%3D%0A&m=hrx5yjIXJ2uqo09c9TlX%2FsiAMrR4p2je3XZQbgBj3Ds%3D%0A&s=842f30
>>136d7a942e3b19f84dfc0f224b8f9006e35853b2ac2d585e709575eecd) because the
>>RSB was
>> branched yesterday.
>I have push a change on the master branch of the RSB. Can you please
>test it and report back ?
>I would like urge everyone to update and test.
>Thanks.
>Chris
>_______________________________________________
>users mailing list
>users at rtems.org
>https://urldefense.proofpoint.com/v1/url?u=http://lists.rtems.org/mailman/
>listinfo/users&k=ZVNjlDMF0FElm4dQtryO4A%3D%3D%0A&r=akrirLnAihUFmXpddZqcJw%
>3D%3D%0A&m=hrx5yjIXJ2uqo09c9TlX%2FsiAMrR4p2je3XZQbgBj3Ds%3D%0A&s=26406b37e
>c72b345627b03049ab46b41e7b75e0b329a6cc93489dcbe9bf5739a
