rtems-tester
Ben Gras beng at shrike-systems.com
Tue Jul 21 17:45:36 UTC 2015
All,
Reading through your message, the one thing I notice is:
> Number of SMP cpus requested (2), exceeds max cpus supported by machine `xilinx-zynq-a9' (1)
You seem to think this is an RTEMS message, whereas I think this is a
qemu message.
I hope that is of help.
Cheers,
Ben
On Tue, Jul 21, 2015 at 7:13 PM, Ric Claus <claus at slac.stanford.edu> wrote:
> Hello All,
>   First, I apologize for the length of this message.  I hope you can bear with me as there are several points I’d like some help with.
>   I’m following https://git.rtems.org/rtems-tools/tree/doc/rtems-tester.txt to try out the xilinx_zynq_a9_qemu RTEMS BSP built with --enable-smp in the configure line.
> I found the use of the term BSP in this document confusing.  "./rtems-test —list-bsps" lists names that are different from those in the RTEMS tree.  For example, modifying the example as follows won’t work:
> $ ../../rtems.git/configure —target=arm-rtems4.11 \
>                     --enable-tests --enable-rtemsbsp=xilinx_zynq_a9_qemu_smp
> Maybe some clarification here might help the next person.
> Next, for me:
> $ arm-rtems4.11-run arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/hello/hello.exe
> returns nothing, and the GDB example returns:
> (gdb) tar sim
> Connected to the simulator.
> (gdb) load
> Loading section .start, size 0x888 vma 0x0
> Loading section .text, size 0x28b2c vma 0x8c0
> Loading section .init, size 0xc vma 0x293ec
> Loading section .fini, size 0xc vma 0x293f8
> Loading section .rodata, size 0x1380 vma 0x29408
> Loading section .ARM.exidx, size 0x8 vma 0x2a788
> Loading section .eh_frame, size 0x74 vma 0x2a790
> Loading section .init_array, size 0x4 vma 0x2a804
> Loading section .fini_array, size 0x4 vma 0x2a808
> Loading section .jcr, size 0x4 vma 0x2a80c
> Loading section .data, size 0x970 vma 0x102800
> Start address 0x40
> Transfer rate: 1411616 bits in <1 sec.
> (gdb) r
> Starting program: /u1/home/claus/development/rtems/bld/xilinx_zynq/a9_qemu/arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/hello/hello.exe
> [Inferior 1 (process 42000) exited with code 060]
> Can someone explain why, please?  Should this work?
> On the other hand, QEMU works and gives:
> qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none -nographic -M xilinx-zynq-a9 -m 256M -smp cpus=1 -kernel $(find bld/xilinx_zynq/a9_qemu/ -name hello.exe)
> Warning: nic cadence_gem.0 has no peer
> Warning: nic cadence_gem.1 has no peer
> *** BEGIN OF TEST HELLO WORLD ***
> Hello World
> *** END OF TEST HELLO WORLD ***
> However, with 2 cores enabled:
> qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none -nographic -M xilinx-zynq-a9 -m 256M -smp cpus=2 -kernel $(find bld/xilinx_zynq/a9_qemu/ -name hello.exe)
> it fails with:
> I verified as per the "SMP support for Raspberry Pi 2” thread that —enable-smp was really set during configure, the cpuopts.h files have "#define RTEMS_SMP 1”, and ZYNQ_CPUS = 2 in $DEV_ROOT/rtems/bld/a9_qemu/arm-rtems4.11/c/xilinx_zynq_a9_qemu/lib/libbsp/arm/xilinx-zynq/Makefile and config.status.  ticker.exe runs and smp01.exe produces no output in QEMU, when I leave the -smp parameter off.  What is the status of the ZYNQ BSPs?  Is the 2nd core nominally started, or is that something I need to work on?  Why is QEMU thinking there is only one core configured?
> Next, I tried to adapt the instructions in rtems-tester.txt to use QEMU:
> $DEV_ROOT/rtems/test/rtems-tools.git/tester/rtems-test \
> --log=log_xilinx_zynq_a9_qemu \
> --rtems-bsp=xilinx_zynq_a9_qemu_smp \
> --rtems-tools=$DEV_ROOT/rtems/4.11 \
> $DEV_ROOT/rtems/bld/xilinx_zynq/a9_qemu/arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites
> Initially, this failed with:
> RTEMS Testing - Tester, v0.2.0
> error: BSP script not found: xilinx_zynq_a9_qemu
> I think there is an incorrect line in:
> $DEV_ROOT/rtems/test/rtems-tools.git/tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.mc
> realview_pbx_a9_qemu should be xilinx_zynq_a9_qemu, right?
> Once I made that change, the tester seems to run, but most tests fail with:
> error: qemu.cfg:65: execute failed: qemu-system-arm -no-reboot -monitor none -serial stdio -nographic -net none -M xilinx-zynq-a9 -m 256M -smp cpus=2 -kernel bld/xilinx_zynq/a9_qemu/arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/fstests/fsbdpart01/fsbdpart01.exe: exit-code:1
> warning: switched to dry run due to errors
> Are these all due to the "-smp cpus=2” parameter?
>   Thanks very much for any help you can give me!
>   Cheers,
>           Ric
> users mailing list
> users at rtems.org
