rtems-tester
Ric Claus
claus at slac.stanford.edu
Wed Jul 22 13:35:14 UTC 2015
On Jul 22, 2015, at 3:19 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 22/07/2015 3:13 am, Ric Claus wrote:
>> Hello All,
>> First, I apologize for the length of this message. I hope you can bear with me as there are several points I’d like some help with.
> Thanks for the review and detailed post.
>> I’m following https://git.rtems.org/rtems-tools/tree/doc/rtems-tester.txt to try out the xilinx_zynq_a9_qemu RTEMS BSP built with --enable-smp in the configure line.
>> I found the use of the term BSP in this document confusing. "./rtems-test —list-bsps" lists names that are different from those in the RTEMS tree. For example, modifying the example as follows won’t work:
>> $ ../../rtems.git/configure —target=arm-rtems4.11 \
>> --enable-tests --enable-rtemsbsp=xilinx_zynq_a9_qemu_smp
>> Maybe some clarification here might help the next person.
I’ve attached some patches to hopefully help with this.
> I wonder if the confusion is in some of the BSP names and the option
> naming in the tester. I wonder if the option '--list-bsps' in the tester
> should be '--list-testers’ ?
Good idea. But if you do that, maybe --rtems-bsp should change, too. Maybe to --tester, --tester-bsp or --rtems-tester, or ...?
> RTEMS uses a configure option --enable-smp to specify an SMP build while
> the tester's configuration is fixed in the tester so we need separate
> tester configurations for a uniprocessor test run and an SMP test run
> for the same BSP. Testing needs to be fixed and controlled and so I do
> not want the tester to support options, eg SMP.
> To further confuse things there are BSPs in RTEMS whose names include
> SMP, for example realview_pbx_a9_qemu_smp. Does building
> realview_pbx_a9_qemu_smp require the --enable-smp configure option ? I
> do not know. There is no consistent behavior which leads to
> realview_pbx_a9_qemu and realview_pbx_a9_qemu_smp as well as
> xilinx_zynq_a9_qemu plus the --enable-smp option.
That brings up another idea: Maybe leave the --list-bsps and --rtems-bsp alone but let them only return and accept, resp., BSP names found in the RTEMS repository. For the additional bits (if any), require a --bsp-variant option that takes a string that is joined with the BSP name to create the tester name. --list-bsps could show the BSP: list of variants.
I don’t know. I think I don’t like this either, except that it provides some clarity.
> Unifying the arch/bsp naming is an on going effort. It is difficult to
> change in the current build tree and my hope with the waf and RTEMS 5.0
> effort we can get a step closer. I have introduced the BSP naming of
> 'arch/bsp' as a standard to the RSB 3rd party building as well as the
> waf build support for packages such as examples-v2. I would like this to
> flow across the whole project.
Of course, this is the better idea.
> For the short term to help users I have added a script called rtems-bsps
> to the top of the source tree. It will find all the available BSP in the
> source and the path helps you figure out the variants.
>> Next, for me:
>> $ arm-rtems4.11-run arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/hello/hello.exe
>> returns nothing, and the GDB example returns:
>> (gdb) tar sim
>> Connected to the simulator.
>> (gdb) load
>> Loading section .start, size 0x888 vma 0x0
>> Loading section .text, size 0x28b2c vma 0x8c0
>> Loading section .init, size 0xc vma 0x293ec
>> Loading section .fini, size 0xc vma 0x293f8
>> Loading section .rodata, size 0x1380 vma 0x29408
>> Loading section .ARM.exidx, size 0x8 vma 0x2a788
>> Loading section .eh_frame, size 0x74 vma 0x2a790
>> Loading section .init_array, size 0x4 vma 0x2a804
>> Loading section .fini_array, size 0x4 vma 0x2a808
>> Loading section .jcr, size 0x4 vma 0x2a80c
>> Loading section .data, size 0x970 vma 0x102800
>> Start address 0x40
>> Transfer rate: 1411616 bits in <1 sec.
>> (gdb) r
>> Starting program: /u1/home/claus/development/rtems/bld/xilinx_zynq/a9_qemu/arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/hello/hello.exe
>> [Inferior 1 (process 42000) exited with code 060]
>> Can someone explain why, please? Should this work?
> The ARM GDB simulator does not support the same Zynq hardware. The
> rtems-bsps script shows the following are based on the gdbarmsim BSP:
> arm1136jfs c/src/lib/libbsp/arm/gdbarmsim
> arm1136js c/src/lib/libbsp/arm/gdbarmsim
> arm7tdmi c/src/lib/libbsp/arm/gdbarmsim
> arm920 c/src/lib/libbsp/arm/gdbarmsim
> armcortexa9 c/src/lib/libbsp/arm/gdbarmsim
> Last time I tried running these BSPs there were problems. I cannot
> remember what they were.
Okay. I guess I just had to learn that arm-rtems4.11-run and arm-rtems4.11-gdb with a sim target isn’t valid for some BSPs.
>> On the other hand, QEMU works and gives:
>> qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none -nographic -M xilinx-zynq-a9 -m 256M -smp cpus=1 -kernel $(find bld/xilinx_zynq/a9_qemu/ -name hello.exe)
>> Warning: nic cadence_gem.0 has no peer
>> Warning: nic cadence_gem.1 has no peer
>> *** BEGIN OF TEST HELLO WORLD ***
>> Hello World
>> *** END OF TEST HELLO WORLD ***
> Great.
>> However, with 2 cores enabled:
>> qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none -nographic -M xilinx-zynq-a9 -m 256M -smp cpus=2 -kernel $(find bld/xilinx_zynq/a9_qemu/ -name hello.exe)
>> it fails with:
>> Number of SMP cpus requested (2), exceeds max cpus supported by machine `xilinx-zynq-a9' (1)
> Same executable as the previous run ?
Yes.
> Where did the qemu come from ?
$DEV_ROOT/rtems/src/rtems-source-builder/bare/source-builder/sb-set-builder --prefix=$DEV_ROOT/rtems/4.11 devel/qemu
>> I verified as per the "SMP support for Raspberry Pi 2” thread that —enable-smp was really set during configure, the cpuopts.h files have "#define RTEMS_SMP 1”, and ZYNQ_CPUS = 2 in $DEV_ROOT/rtems/bld/a9_qemu/arm-rtems4.11/c/xilinx_zynq_a9_qemu/lib/libbsp/arm/xilinx-zynq/Makefile and config.status. ticker.exe runs and smp01.exe produces no output in QEMU, when I leave the -smp parameter off. What is the status of the ZYNQ BSPs? Is the 2nd core nominally started, or is that something I need to work on? Why is QEMU thinking there is only one core configured?
>> Next, I tried to adapt the instructions in rtems-tester.txt to use QEMU:
>> $DEV_ROOT/rtems/test/rtems-tools.git/tester/rtems-test \
>> --log=log_xilinx_zynq_a9_qemu \
>> --rtems-bsp=xilinx_zynq_a9_qemu_smp \
>> --rtems-tools=$DEV_ROOT/rtems/4.11 \
>> $DEV_ROOT/rtems/bld/xilinx_zynq/a9_qemu/arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites
>> Initially, this failed with:
>> RTEMS Testing - Tester, v0.2.0
>> error: BSP script not found: xilinx_zynq_a9_qemu
>> I think there is an incorrect line in:
>> $DEV_ROOT/rtems/test/rtems-tools.git/tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.mc
>> realview_pbx_a9_qemu should be xilinx_zynq_a9_qemu, right?
> Yes I agree. Patch ?
Attached.
>> Once I made that change, the tester seems to run, but most tests fail with:
>> error: qemu.cfg:65: execute failed: qemu-system-arm -no-reboot -monitor none -serial stdio -nographic -net none -M xilinx-zynq-a9 -m 256M -smp cpus=2 -kernel bld/xilinx_zynq/a9_qemu/arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/fstests/fsbdpart01/fsbdpart01.exe: exit-code:1
>> warning: switched to dry run due to errors
> Is this all the log contains ?
Yes, but with a line for every test.
> Can you please try the --report-mode=all option ?
Okay, that does show that all tests are being marked invalid due to the “The number of SMP cpus...” line. Where does one configure QEMU with the appropriate number of cores?
It stopped making progress after printing the line for tmoverhd.exe. It’s been hanging there for the last half hour or so. The last line in the log is:
error: qemu.cfg:66: execute failed: qemu-system-arm -no-reboot -serial null -serial mon:stdio -nographic -net none -M xilinx-zynq-a9 -m 256M -smp cpus=2 -kernel /home/claus/development/rtems/bld/xilinx_zynq/a9_qemu/arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/tmtests/tmoverhd/tmoverhd.exe: exit-code:1
>> Are these all due to the "-smp cpus=2” parameter?
> I suppose so. Did the uniprocessor test run work ?
It looked like it, but every test had status invalid due to missing test output. I changed qemu.cfg to modify the options from "-monitor none -serial stdio" to "-serial null -serial mon:stdio” (patch attached). That resulted in:
Passed: 566
Failed: 3
Timeouts: 6
Invalid: 1
Total: 576
Failures:
smpcapture02.exe
sp69.exe
sptimecounter02.exe
Timeouts:
spintrcritical06.exe
spintrcritical07.exe
spintrcritical11.exe
spintrcritical14.exe
spintrcritical12.exe
spintrcritical15.exe
Invalid:
spfatal20.exe
Average test time: 0:00:00.665570
Testing time : 0:06:23.368485
> Chris
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20150722/091dd461/attachment-0004.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20150722/091dd461/attachment-0005.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20150722/091dd461/attachment-0006.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20150722/091dd461/attachment-0007.obj>
