RTEMS on Beaglebone Black
Steve B
sbattazzo at gmail.com
Mon Jul 27 15:54:03 UTC 2015
Hi Angelo,
Here's a handy diagram that shows which ones are which (found on Google
Images):
http://cholla.mmto.org/computers/beagle/hardware/pinout1-1024x585.png
GPIO1_12 is connector P8 pin 12. I think I used the adjacent pin (P8 pin
11, or GPIO1_13) and installed a jumper wire between the two.
I think it says so in my comments too but I know that may not exactly jump
out.
Steve
On Sun, Jul 26, 2015 at 6:38 PM, Angelo Fraietta <
newsgroups at smartcontroller.com.au> wrote:
> Greetings Steve, I have modified your code so the standard task only
> toggles one LED and the interrupt on GPIO12 should toggle the other 3.
> However, IO cannot for the life of me find which pin is GPIO12 so I can
> test on the hardware. I have posted the code with the mods I made at the
> bottom of this email
> http://beagleboard.org/support/bone101
> What physical pin should I be toggling to make it work?
> Thanks
URL: <http://lists.rtems.org/pipermail/users/attachments/20150727/fe69ddb5/attachment.html>
