RTEMS on Beaglebone Black
Angelo Fraietta
newsgroups at smartcontroller.com.au
Wed Jul 29 04:46:39 UTC 2015
I found the GPIO3 issue
from https://github.com/majestik666/Beagle_GPIO/blob/master/Beagle_GPIO.cc
I found the correct define would be
#define GPIO3_ADDR 0x481AE000
I just have to find out why the other pins failed
On Wed, Jul 29, 2015 at 1:30 PM, Angelo Fraietta <
newsgroups at smartcontroller.com.au> wrote:
> I have done some more tests to check whether all inputs actually work.
> I set all as inputs like this in the init
> *(unsigned long *)(GPIO0_ADDR+OE_ADDR) = 0xFFFFFFFF;
> *(unsigned long *)(GPIO1_ADDR+OE_ADDR) = 0xFFFFFFFF;
> *(unsigned long *)(GPIO2_ADDR+OE_ADDR) = 0xFFFFFFFF;
> *(unsigned long *)(GPIO3_ADDR+OE_ADDR) = 0xFFFFFFFF;
> And read them in a task while switching the pins between 1 and zero
> data_0 = *(unsigned long *)(GPIO0_ADDR+GPIO_DATAIN);
> data_1 = *(unsigned long *)(GPIO1_ADDR+GPIO_DATAIN);
> data_2 = *(unsigned long *)(GPIO2_ADDR+GPIO_DATAIN);
> data_3 = *(unsigned long *)(GPIO3_ADDR+GPIO_DATAIN);
> I found that GPIO1_0 to GPIO1_3 did not work
> I found that GPIO1_30 and GPIO1_31 did not work
> I found that GPIO0_4 and GPIO0_5 did not work
> I found GPIO1_16 is actually GPIO2_0 - which is very strange as all the
> other GPIO2 are on P8
> I found none of GPIO3 read a value
> Anyone have have any suggestions? Maybe an incorrect address for GPIO3?
> #define GPIO0_ADDR 0x44E07000
> #define GPIO1_ADDR 0x4804C000
> #define GPIO2_ADDR 0x481AC000
> #define GPIO3_ADDR 0x481AF000
> Thanks
> On Wed, Jul 29, 2015 at 11:49 AM, Chris Johns <chrisj at rtems.org> wrote:
>> On 29/07/2015 2:01 am, Joel Sherrill wrote:
>> > On 7/28/2015 8:39 AM, Mr. Andrei Chichak wrote:
>> >> Hey Angelo,
>> >> If you have about an hour, listen to the embedded.fm podcast #110
>> >> (www.embedded.fm <http://www.embedded.fm> or iTunes). They talk with
>> >> Jason Kridner of Beagleboard.org <http://Beagleboard.org>, also from
>> >> TI. He wants people to send him queries about the Beagle Boards, like
>> >> your pinout questions.
>> >> RTEMS even comes up in the conversation.
>> > I saw a tweet on this last week. I need to listen to Jason also.
>> > He is a nice guy and the embedded.fm podcast is a great resource.
>> Great podcast.
>> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20150729/bd9dbf61/attachment.html>
