Coressent Korea - Freescale i.MX6 RTEMS/Qt SDK Release Information.
JunBeom Kim (Coressent) jbkim at coressentkorea.co.kr
Fri Jul 31 05:21:43 UTC 2015
Dear All,
I added new video clip for Automotive Dash board using RTEMS/Qt on Freescale
i.MX6 SDP board.
https://youtu.be/XtGHrLnUWCA : Automotive Dash Board (New)
https://youtu.be/NwCoU-SpP6Y : Animated Tiles
https://youtu.be/0DnZcDmuBBE : Medical Demo
Best Regards,
JunBeom
-----Original Message-----
From: JunBeom Kim (Coressent) [mailto:jbkim at coressentkorea.co.kr]
Sent: Thursday, July 16, 2015 12:04 AM
To: 'users at rtems.org'
Subject: RE: Coressent Korea - Freescale i.MX6 RTEMS/Qt SDK Release
Information.
Dear All,
Please reference RTEMS Qt demo video in below URL.
https://youtu.be/NwCoU-SpP6Y : Animated Tiles Demo
Next Qt GUI demo will be dash board for automotive market.
Best Regards,
JunBeom
From: users [mailto:users-bounces at rtems.org] On Behalf Of JunBeom Kim
(Coressent)
Sent: Tuesday, July 14, 2015 3:25 PM
To: 'Chris Johns'; 'Gedare Bloom'
Cc: users at rtems.org
Information.
Dear Chris,
Thank you very much for your comment.
1. select()
  - I will try to use rtems-libbsd soon regarding this.
2. mmap()
  - Qt 4.8 can be built without mmap feature.
  - If I need mmap for Qt 5.x, I will use your mmap code. Thank you.
3. fstatvfs()
  - I tried to implemented fstatvfs() for Qt. but, I was failed.
  - As I check from GCC toolchain for Linux, there is fstatvfs(). But, there
is not this function from GCC toolchain for RTEMS. I don't know reason. If
there is a method for adding this function on RSB build process, this
problem will be resolved.
4. Shared library
  - I didn't test libdl for this. I will try to use libdl for porting WebKit
of Qt 4.8 or WebEngine of Qt 5.5.
5. Your comment, "How do they build Qt with the same code base ?"
  - I referenced QNX interface layer due to almost same POSIX API. But, API
between QNX and RTEMS is not equal in 100%. Therefore, a user should patch
Qt source.
Best Regards,
JunBeom
Sent: Tuesday, July 14, 2015 3:00 PM
To: JunBeom Kim (Coressent); 'Gedare Bloom'
Subject: Re: Coressent Korea - Freescale i.MX6 RTEMS/Qt SDK Release
Information.
On 14/07/2015 2:56 pm, JunBeom Kim (Coressent) wrote:
> - select() : select() function should be patched for calling select()
> by
Qt Event dispatcher.
The rtems-libbsd project may help here.
> - mmap() : because mmap is not supported on RTEMS, Qt should be patched.
Do these files ....
 https://git.rtems.org/chrisj/rtl.git/tree/mmap.c
 https://git.rtems.org/chrisj/rtl.git/tree/munmap.c
 https://git.rtems.org/chrisj/rtl.git/tree/mmap-internal.h
help ?
> - fstatvfs() : because fstatvfs() is not supported in GCC toolchain
library, Qt File Dialog should be disabled.
Could you add this support to RTEMS ?
> - shared library : because this is not supported, QtWebKit can not be
ported.
There is libdl. What is the API used ?
> - OpenGL ES : because there is not OpenGL ES for RTEMS, Qt Quick can
> not
be ported. If there is OpenGL ES driver for RTEMS, there is possibility for
porting Qt Quick.
> - No process model : because RTEMS can not support OS process model,
> Qt
pthread only is supported.
Correct, RTEMS is a single address space.
> 2. Qt License issue.
> I have discussed with Qt company regarding Qt distribution for RTEMS
> in
many times.
> Important thing is that Qt source should be modified in many parts due
> to
RTEMS technical issue.
> Because we modified Qt source and Qt library is linked with RTEMS
statically, we can not provide open community or customers with Qt porting
source code(Open Source License / GPL&LGPL). That is, customer should
purchase Qt commercial license. This is very headache issue in customer
considering point.
> If user want to use RTOS solution on Qt open source license, there are
three RTOS solution vendors(QNX, VxWorks, Integrity). But, these RTOS
solution have royalty business model.
> I guess that Qt license is better condition than RTOS license.
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
