Hello_via_task Ada example on Rapberry
Thu Jul 16 21:58:23 UTC 2015
The free lines look like you might not be printing the address freed
correctly but it doesn't matter. I don't think it explains anything you
are seeing.
I built a SPARC Ada toolset. Can you post your test case including
Makefile, etc.? Just tar up the directory.
I want to see if I can tell what is happening.
FWIW attached is the patch I needed to build the 4.9 branch of gcc
current as of today.
On 7/15/2015 4:23 PM, Jan Sommer wrote:
> I placed the debug statements in the files you suggested, rebuild rtems and compiled both examples: hello_world_ada (which works) and hello_via_task (which hangs).
> The output from generated by workspace_allocate are basically the same they only differ in the addresses they print, but the size and order of the allocation are the same, except that for the hello_via_task example one additional allocation is called at the very end.
> However several allocations seem to have failed, especially in the beginning (but in both examples). I don't know if this is a severe failure, or if it is expected to happen. Nevertheless the output I get the hello_via_task example is the following (as said before the output for the hello_ada example is the same except for the last allocation):
> Workspace_Allocate_or_fatal_error(24) from 44A50/0 -> 10ED78
> Workspace_Allocate_or_fatal_error(112) from 4161C/0 -> 10EDB8
> Workspace_Allocate_or_fatal_error(28) from 41660/0 -> 10EE50
> Workspace_Free(0) from 4173C/0
> Workspace_Allocate_or_fatal_error(1304) from 4161C/0 -> 10EE90
> Workspace_Allocate_or_fatal_error(24) from 41660/0 -> 10F3D0
> Workspace_Allocate_or_fatal_error(26080) from 4161C/0 -> 10F410
> Workspace_Allocate_or_fatal_error(100) from 41660/0 -> 115A18
> Workspace_Allocate(480) from 417CC/0 -> 115AA0
> Workspace_Allocate(52) from 417E0/0 -> 115CA8
> Workspace_Allocate(736) from 417CC/0 -> 115D00
> Workspace_Allocate(52) from 417E0/0 -> 116008
> Workspace_Allocate_or_fatal_error(1512) from 4161C/0 -> 116060
> Workspace_Allocate_or_fatal_error(128) from 41660/0 -> 116670
> Workspace_Allocate(384) from 417CC/0 -> 116718
> Workspace_Allocate(52) from 417E0/0 -> 1168C0
> Workspace_Allocate(1856) from 417CC/0 -> 116918
> Workspace_Allocate(52) from 417E0/0 -> 117080
> Workspace_Allocate(224) from 417CC/0 -> 1170D8
> Workspace_Allocate(52) from 417E0/0 -> 1171E0
> Workspace_Allocate(1664) from 417CC/0 -> 117238
> Workspace_Allocate(52) from 417E0/0 -> 1178E0
> Workspace_Allocate(416) from 417CC/0 -> 117938
> Workspace_Allocate(52) from 417E0/0 -> 117B00
> Workspace_Allocate(180) from 417CC/0 -> 117B58
> Workspace_Allocate(56) from 417E0/0 -> 117C30
> Workspace_Allocate_or_fatal_error(288) from 402EC/0 -> 117C90
> Workspace_Allocate(36512) from 417CC/0 -> 117DD8
> Workspace_Allocate(132) from 417E0/0 -> 120CA0
> Workspace_Allocate(1232) from 417CC/0 -> 120D48
> Workspace_Allocate(132) from 417E0/0 -> 121240
> Workspace_Allocate(2128) from 417CC/0 -> 1212E8
> Workspace_Allocate(172) from 417E0/0 -> 121B60
> Workspace_Allocate(960) from 417CC/0 -> 121C30
> Workspace_Allocate(52) from 417E0/0 -> 122018
> Workspace_Allocate(192) from 417CC/0 -> 122070
> Workspace_Allocate(52) from 417E0/0 -> 122158
> Workspace_Allocate(480) from 417CC/0 -> 1221B0
> Workspace_Allocate(52) from 417E0/0 -> 1223B8
> Workspace_Allocate(928) from 417CC/0 -> 122410
> Workspace_Allocate(52) from 417E0/0 -> 1227D8
> Workspace_Allocate(384) from 417CC/0 -> 122830
> Workspace_Allocate(52) from 417E0/0 -> 1229D8
> Workspace_Allocate(384) from 417CC/0 -> 122A30
> Workspace_Allocate(52) from 417E0/0 -> 122BD8
> Workspace_Allocate(256) from 417CC/0 -> 122C30
> Workspace_Allocate(52) from 417E0/0 -> 122D58
> Workspace_Allocate(4096) from 4448C/0 -> 122DB0
> Workspace_Allocate(8192) from 4448C/0 -> 124000
> Workspace_Allocate(102400) from 4448C/0 -> 126398
> Workspace_Allocate(16384) from 4448C/0 -> 142CF8
> *** GNAT/RTEMS Hello World Test ***
> Welcome to the World of Lady Ada
> Initiating 2.5 second delay
> Am Dienstag, 14. Juli 2015, 15:26:01 schrieb Joel Sherrill:
>> On 7/14/2015 3:13 PM, Jan Sommer wrote:
>>> One question. If the Ada main thread is created using pthread in the beginning and then creates new task
>>> (in Ada), do these tasks take their stack from the Ada main thread or do they get their own stack
>>> allocated from available memory?
>> Ada tasks are just pthreads and their stack comes from the workspace.
>> One option is some selectively placed debug statements.
>> + score/src/objectallocate.c already has a debug section you
>> can turn on to print on object allocation failure. This would
>> let you know if you ran out of pthreads, semaphores, etc.
>> + libcsupport/src/malloc.c for a NULL being returned.
>> + score/src/wkspace.c - _Workspace_Allocate for a NULL being
>> returned. There is a printk in here which prints every allocation
>> and the return addresses.
>> If it is a resource issue, that should help narrow it down.
>>> Am Sonntag, 12. Juli 2015, 18:31:57 schrieb Jan Sommer:
>>>> Am Sonntag, 12. Juli 2015, 10:26:56 schrieb Joel Sherrill:
>>>>> Just to make sure we are on the same page, what gcc version?
>>>> gcc 4.9.2
>>>>> It sounds like the number of resources configured might be off. Can you try unlimited objects and unified workspace? They are CONFIGURE_ parameters.
>>>> I added
>>>> #define CONFIGURE_UNIFIED_WORK_AREAS
>>>> #define CONFIGURE_UNLIMITED_OBJECTS
>>>> to the rtems-init.c of the Ada examples I hope this does not conflict with the other defines like
>>>> #define CONFIGURE_MAXIMUM_TASKS                         20
>>>> #define CONFIGURE_MAXIMUM_SEMAPHORES          20
>>>> #define CONFIGURE_GNAT_RTEMS
>>>> #define CONFIGURE_MAXIMUM_ADA_TASKS      20
>>>> #if !defined(CONFIGURE_MAXIMUM_FAKE_ADA_TASKS)
>>>>     #define CONFIGURE_MAXIMUM_FAKE_ADA_TASKS 0
>>>> #endif
>>>> #if !defined(ADA_APPLICATION_NEEDS_EXTRA_MEMORY)
>>>>     #define ADA_APPLICATION_NEEDS_EXTRA_MEMORY 0
>>>> #endif
>>>> /* Account for any extra task stack size */
>>>> #define CONFIGURE_MEMORY_OVERHEAD \
>>>>     (ADA_APPLICATION_NEEDS_EXTRA_MEMORY + GNAT_MAIN_STACKSPACE)
>>>> Still the task hangs after it calls the delay.
>>>> Best regards,
>>>>     Jan
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
>>> users mailing list
>>> users at rtems.org
diff --git a/gcc/ada/Make-generated.in b/gcc/ada/Make-generated.in
index 412e18b..574e203 100644
--- a/gcc/ada/Make-generated.in
+++ b/gcc/ada/Make-generated.in
@@ -78,7 +78,7 @@ OSCONS_CC=$(subst ./xgcc,../../../xgcc,$(subst -B./, -B../../../,$(GCC_FOR_TARGE
 # has a <types.h> header).
 OSCONS_SRCDIR=$${_oscons_srcdir}
-OSCONS_CPP=$(OSCONS_CC) $(GNATLIBCFLAGS) -E -C \
+OSCONS_CPP=$(OSCONS_CC) X $(GNATLIBCFLAGS) $(CFLAGS_FOR_TARGET) -E -C \
   -DTARGET=\"$(target)\" -iquote $(OSCONS_SRCDIR) s-oscons-tmplt.c > s-oscons-tmplt.i
 OSCONS_EXTRACT=$(OSCONS_CC) -iquote $(OSCONS_SRCDIR) -S s-oscons-tmplt.i
diff --git a/gcc/ada/gcc-interface/Makefile.in b/gcc/ada/gcc-interface/Makefile.in
index e2cc4a9..b216dd6 100644
--- a/gcc/ada/gcc-interface/Makefile.in
+++ b/gcc/ada/gcc-interface/Makefile.in
@@ -2748,7 +2748,7 @@ else
 # for running it from $(RTSDIR)
 OSCONS_CC=`echo "$(GCC_FOR_TARGET)" \
   | sed -e 's^\./xgcc^../../xgcc^' -e 's^-B./^-B../../^'`
+OSCONS_CPP=$(OSCONS_CC) $(GNATLIBCFLAGS) $(CFLAGS_FOR_TARGET) -E -C \
   -DTARGET=\"$(target)\" $(fsrcpfx)ada/s-oscons-tmplt.c > s-oscons-tmplt.i
 OSCONS_EXTRACT=$(OSCONS_CC) $(GNATLIBCFLAGS) -S s-oscons-tmplt.i
 endif
diff --git a/gcc/ada/s-osinte-rtems.ads b/gcc/ada/s-osinte-rtems.ads
index 8b9ae12..a972c88 100644
--- a/gcc/ada/s-osinte-rtems.ads
+++ b/gcc/ada/s-osinte-rtems.ads
@@ -186,6 +186,11 @@ package System.OS_Interface is
       tp       : access timespec) return int;
    pragma Import (C, clock_gettime, "clock_gettime");
+   function clock_getres
+     (clock_id : clockid_t;
+      res      : access timespec) return int;
+   pragma Import (C, clock_getres, "clock_getres");
    function To_Duration (TS : timespec) return Duration;
    pragma Inline (To_Duration);
