RTEMS on Beaglebone Black
Angelo Fraietta newsgroups at smartcontroller.com.au
Mon Jul 27 22:07:14 UTC 2015
What is bazaar is that the pins are labelled differently to
http://beagleboard.org/support/bone101
On Tue, Jul 28, 2015 at 1:54 AM, Steve B <sbattazzo at gmail.com> wrote:
> Hi Angelo,
> Here's a handy diagram that shows which ones are which (found on Google
> Images):
> http://cholla.mmto.org/computers/beagle/hardware/pinout1-1024x585.png
> GPIO1_12 is connector P8 pin 12. I think I used the adjacent pin (P8 pin
> 11, or GPIO1_13) and installed a jumper wire between the two.
> I think it says so in my comments too but I know that may not exactly jump
> out.
> Steve
> On Sun, Jul 26, 2015 at 6:38 PM, Angelo Fraietta <
> newsgroups at smartcontroller.com.au> wrote:
>> Greetings Steve, I have modified your code so the standard task only
>> toggles one LED and the interrupt on GPIO12 should toggle the other 3.
>> However, IO cannot for the life of me find which pin is GPIO12 so I can
>> test on the hardware. I have posted the code with the mods I made at the
>> bottom of this email
>> What physical pin should I be toggling to make it work?
>> Thanks
URL: <http://lists.rtems.org/pipermail/users/attachments/20150728/a590b291/attachment-0002.html>
