Need help in getting started with Raspberry PI
Tue Jul 28 19:42:10 UTC 2015
The gdb simulator does not support the Raspberry Pi. There was a recent
post indicating you can build a Qemu version taht simulates RPi with
http://wiki.osdev.org/Raspberry_Pi_Bare_Bones#Testing_your_operating_system_.28QEMU.29
But since you have the board itself, you might want to just try loading the
image to it? Alan Cudmore had posted a blog post on how to do this you
might search for.
Gedare
On Tue, Jul 28, 2015 at 3:07 PM, Deval Shah <deval.maker at gmail.com> wrote:
> Hello everyone,
> I am new to RTEMS users group. I recently started working with RTEMS and
> with the help of quick start guide, I could build and simulate sparc-rtems
> successfully.
> Since I have a Raspberry PI B+ model, I wanted to run RTEMS on it. But I
> could not get through. I built using following command and it was
> successfully built.
> $ ../rtems/configure --target=arm-rtems4.11 --enable-rtemsbsp=raspberrypi
>  --enable-tests=samples  --enable-networking  --enable-posix
> I also tried to make an image of ticker sample(arm-rtems4.11-objcopy
> -Obinary ticker.exe kernel.img). But I didn't get anything to the serial
> port. (Using USB to TTL cable and minicom software in host) I followed this
> link:
> http://alanstechnotes.blogspot.in/2013/03/running-your-first-rtems-program-on.html
> Running on simulator gave me this results:
> GNU gdb (GDB) 7.9
> Copyright (C) 2015 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <
> http://gnu.org/licenses/gpl.html>
> <http://s.bl-1.com/h/qmh6Jvg?url=http://gnu.org/licenses/gpl.html%3E>;
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "--host=x86_64-linux-gnu
> --target=arm-rtems4.11".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>
> <http://s.bl-1.com/h/qmh6NJj?url=http://www.gnu.org/software/gdb/bugs/%3E>
> Find the GDB manual and other documentation resources online at:
> <http://www.gnu.org/software/gdb/documentation/>
> <http://s.bl-1.com/h/qmh6Tjl?url=http://www.gnu.org/software/gdb/documentation/%3E>
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> Reading symbols from
> ./arm-rtems4.11/c/raspberrypi/testsuites/samples/ticker/ticker.exe...done.
> (gdb) tar sim
> Connected to the simulator.
> (gdb) load
> Loading section .start, size 0x340 vma 0x8000
> Loading section .text, size 0x156a0 vma 0x8340
> Loading section .init, size 0x18 vma 0x1d9e0
> Loading section .fini, size 0x18 vma 0x1d9f8
> Loading section .rodata, size 0x1290 vma 0x100000
> Loading section .ARM.exidx, size 0x8 vma 0x101290
> Loading section .eh_frame, size 0x48 vma 0x101298
> Loading section .init_array, size 0x4 vma 0x1012e0
> Loading section .fini_array, size 0x4 vma 0x1012e4
> Loading section .jcr, size 0x4 vma 0x1012e8
> Loading section .data, size 0x698 vma 0x1012f0
> Start address 0x8040
> Transfer rate: 760992 bits in <1 sec.
> (gdb) r
> Starting program:
> /home/deval/development/rtems/b-rpi/arm-rtems4.11/c/raspberrypi/testsuites/samples/ticker/ticker.exe
> sim: MULTIPLY64 - INVALID ARGUMENTS
> [Inferior 1 (process 42000) exited with code 035]
> Thank you.
> Deval
> ᐧ
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150728/46fa1afa/attachment-0002.html>
