RaspberryPI ADA-build causes: undefined reference to `__sync_synchronize'
Jan Sommer
soja-misc at aries.uberspace.de
Mon Jun 1 20:08:55 UTC 2015
Am Freitag, 22. Mai 2015, 08:30:24 schrieb Sebastian Huber:
> > I found this thread where it seems to have been discussed before, but
> > don't see if and how it was solved:
> > http://gcc.gnu.org/ml/gcc/2012-03/msg00083.html What would be a starting
> > point to fix this issue?
> Which GCC options do you use to build or link to the Ada library? It
> should work for the RPI 2, for the RPI 1 we lack a suitable multilib. So
> something like this is necessarry:
> https://gcc.gnu.org/ml/gcc/2012-03/msg00090.html
It may be a stupid question, but for the RPI1 I still don't get where I would
add the function. Somewhere in the gcc sources before compiling the cross
compiler toolchain, in the rtems sources or in the user program?
I found the same mailinglist thread you point to, but unfortunately there it's
not explained.
Best regards,
Jan
