Using dosfs/ida/ata drivers
Tue Jun 2 19:01:04 UTC 2015
On Tue, Jun 2, 2015 at 2:50 PM, Wu, Mark H. <Mark.H.Wu at disney.com> wrote:
> I'm trying to get the file system working on my pc386 machine, and I ran into some issues. At first, I was following the directions on:
> <https://devel.rtems.org/wiki/TBR/UserManual/Using_the_RTEMS_DOS_File_System>, but those don't seem current. Specifically, in rtems/ide_part_table.h, it marks rtems_ide_part_table_initialize() as deprecated.
> So I'm using that as the baseline for the configuration requirements, but I also get an error in confdefs.h when I include:
> #define CONFIGURE_BDBUF_BUFFER_COUNT               1024
> #define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS      64
> #define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS           32
> So I commented out CONFIGURE_BDBUF_BUFFER_COUNT, which was causing an error in confdefs.h.
> Replacing the code that uses rtems_ide_part_table_initialize(), I've looked at the code in testsuites/samples/fileio/init.c, which is very similar to the code listed in https://lists.rtems.org/pipermail/users/2012-November/025807.html, so I ran with that.
> The fileio test binary worked fine... after I read its instructions to find out that you mount /dev/hda instead of /dev/ide0 or /dev/ide1. But I could not get my own application to mount the disk. I kept getting an "Invalid Name" error (return code 3).
> It took a lot of trial and error, but I finally found that I couldn't set CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS to 32. It was failing "silently" in bdbuf.c in rtems_bdbuf_do_init(), because the size was too large. (I checked the math, and it was indeed too large.) Shouldn't the system fail more obviously if it can't initialize?
Yes.
If you would like to file a ticket in our Trac that would be great. Or
maybe someone else will get around to it. If you're really ambitious,
patches are always welcomed too [1].
[1] https://devel.rtems.org/wiki/Developer/Contributing
> Also related, what's the mechanism for reporting errors in documentation such as this? I see that the original page is "To Be Removed," but I have also found some errors in some of the other documentation that I would like to report.
Ignore the "TBR" it is an unintended consequence of part of our
migration from Mediawiki to Trac Wiki, where some pages were flagged
as belonging to the set of pages that should go into, for example, a
user manual. Eventually the Trac wiki may be oriented mostly toward
development of RTEMS. This TBR is a misnomer for such pages.
> users mailing list
> users at rtems.org
