attaching an interrupt in beaglebone bsp
Wed Jun 3 14:23:10 UTC 2015
On Wed, Jun 3, 2015 at 10:04 AM, Ben Gras <beng at shrike-systems.com> wrote:
> All,
> On Tue, Jun 2, 2015 at 1:28 AM, Chris Johns <chrisj at rtems.org> wrote:
>> On 1/06/2015 6:06 pm, Ben Gras wrote:
>>> This tutorial covers everything from scratch and I recently verified the
>>> instructions work & the built result works :).
>>> http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
>> What is outstanding and needs to be merged ?
>> Do Trac tickets exist ?
> Hi Chris,
> I have a large-ish commit for RSB that builds qemu, uboot and some FS
> utilities. This is so a full FS image can be made with provided tools.
> It wasn't merged because of uboot and its license so in my mind this
> is blocking on a replacement becoming available.
I don't personally see a problem with providing a way to build uboot,
although if Chris opposed it that is good enough for me.
> In rtems-tools I have a tester to run the test set using qemu, but
> this depends on changes in RSB.
> Should I open tickets for them even though they're blocked?
Yes. You can also provide them in a fork of RSB if you care to
maintain such a thing.
> users mailing list
> users at rtems.org
