nfs.c not linking
Wed Jun 3 15:25:26 UTC 2015
On Wed, Jun 3, 2015 at 11:21 AM, Ben Dart <Ben.Dart at adept.com> wrote:
> Hi,
> I am trying to build RTEMS 4.9.2 with the command line `mount` enabled for
> nfs mounts. As suggested here:
This version of RTEMS is not really supported by the public community,
although there are probably still enough active and ex-users of it
that you might get help.
> https://docs.rtems.org/releases/rtemsdocs-4.9.2/share/rtems/html/shell/shell00038.html
> I have added the following to shellconfig.h:
> #ifdef RTEMS_NETWORKING
>   #define CONFIGURE_SHELL_MOUNT_NFS
> #endif
I'm not sure what this shellconfig.h is, but you should be including
this in a file your application will include before it includes
confdefs.h, and then you also need to be sure to configure rtems with
--enable-networking.
> This should fill rtems_shell_Mount_filesystems with the NFS mount type and
> allow me to mount with NFS. Unfortunately I am unable to build. I get
> linkers errors as follows:
> 1>../../../../../adept_5200/lib\librtemscpu.a(libshell_a-main_mount_nfs.o):
> In function `rtems_shell_nfs_mounter':
> 1>d:\Subversion\rtems49\Trunk\build_5200\powerpc-rtems4.9\c\adept_5200\cpukit\libmisc/../../../../../../rtems-4.9.2/c/src/../../cpukit/libmisc/shell/main_mount_nfs.c:46:
> undefined reference to `rpcUdpInit'
> 1>d:\Subversion\rtems49\Trunk\build_5200\powerpc-rtems4.9\c\adept_5200\cpukit\libmisc/../../../../../../rtems-4.9.2/c/src/../../cpukit/libmisc/shell/main_mount_nfs.c:51:
> undefined reference to `nfsInit'
> 1>d:\Subversion\rtems49\Trunk\build_5200\powerpc-rtems4.9\c\adept_5200\cpukit\libmisc/../../../../../../rtems-4.9.2/c/src/../../cpukit/libmisc/shell/main_mount_nfs.c:58:
> undefined reference to `nfsMount'
> 1>collect2: ld returned 1 exit status
> Is there something else I need to do to be able to use the ‘mount’ console
> command with TFTP or NFS?
> Ben
> users mailing list
> users at rtems.org
