nfs.c not linking
Ben Dart Ben.Dart at adept.com
Wed Jun 3 20:33:02 UTC 2015
So After the last advice I have checked the following:
1. I am compiling with --enable-networking
2. There is currently no way for us to upgrade to 4.10
3. I have added the following to shellconfig.c as per the instructions here https://docs.rtems.org/releases/rtemsdocs-4.9.2/share/rtems/html/shell/shell00038.html
	#ifdef RTEMS_NETWORKING
  		#define CONFIGURE_SHELL_MOUNT_TFTP
  		#define CONFIGURE_SHELL_MOUNT_FTP
  		#define CONFIGURE_SHELL_MOUNT_NFS
	#endif
This causes the array rtems_shell_Mount_filesystems to look like this:
	rtems_shell_filesystems_t *rtems_shell_Mount_filesystems[] = {
		&rtems_shell_Mount_TFTP,
		&rtems_shell_Mount_FTP,
		&rtems_shell_Mount_NFS,
		NULL
All of this is desired.
When I build this I get the linking error,
1>../../../../../adept_5200/lib\librtemscpu.a(libshell_a-main_mount_nfs.o): In function `rtems_shell_nfs_mounter':
1>d:\Subversion\rtems49\Trunk\build_5200\powerpc-rtems4.9\c\adept_5200\cpukit\libmisc/../../../../../../rtems-4.9.2/c/src/../../cpukit/libmisc/shell/main_mount_nfs.c:46: undefined reference to `rpcUdpInit'
1>d:\Subversion\rtems49\Trunk\build_5200\powerpc-rtems4.9\c\adept_5200\cpukit\libmisc/../../../../../../rtems-4.9.2/c/src/../../cpukit/libmisc/shell/main_mount_nfs.c:51: undefined reference to `nfsInit'
1>d:\Subversion\rtems49\Trunk\build_5200\powerpc-rtems4.9\c\adept_5200\cpukit\libmisc/../../../../../../rtems-4.9.2/c/src/../../cpukit/libmisc/shell/main_mount_nfs.c:58: undefined reference to `nfsMount'
1>../../../../../adept_5200/lib\librtemscpu.a(dummy.o):(.data+0x10): undefined reference to `main'
Important parts are these:
To me this indicates that nfs.c is not being correctly linked to this file? Has there been a bug that describes this behavior? Was anyone ever able to use `mount -t nfs` in 4.9.2?
There is a similar bug reported here: http://www.aps.anl.gov/epics/tech-talk/2012/msg01030.php?format=printer
But this is for 4.10 and I checked the nfs.c and other files and there are no static declarations of these files.
Is there definitely nothing else I need to do to get this working? No additions to make files to link these together correctly? Or any compiler directives?
Thanks again for your help.
Ben
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Wednesday, June 03, 2015 8:29 AM
To: Gedare Bloom; Ben Dart
Cc: users at rtems.org
Subject: Re: nfs.c not linking
On June 3, 2015 11:25:26 AM EDT, Gedare Bloom <gedare at rtems.org> wrote:
>On Wed, Jun 3, 2015 at 11:21 AM, Ben Dart <Ben.Dart at adept.com> wrote:
>> Hi,
>> I am trying to build RTEMS 4.9.2 with the command line `mount`
>enabled for
>> nfs mounts. As suggested here:
>This version of RTEMS is not really supported by the public community,
>although there are probably still enough active and ex-users of it that
>you might get help.
+1 this is old.
>shell00038.html
>> I have added the following to shellconfig.h:
>> #endif
>I'm not sure what this shellconfig.h is, but you should be including
>this in a file your application will include before it includes
>confdefs.h, and then you also need to be sure to configure rtems with
>--enable-networking.
Shellconfig.h is the way to configure the SRT of commands in the shell.
>> This should fill rtems_shell_Mount_filesystems with the NFS mount
>type and
>> allow me to mount with NFS. Unfortunately I am unable to build. I get
>> linkers errors as follows:
>> 1>collect2: ld returned 1 exit status
>> Is there something else I need to do to be able to use the ‘mount’
>console
>> command with TFTP or NFS?
>> Ben
>> users mailing list
>> users at rtems.org
>users mailing list
>users at rtems.org
--joel
