CANopen library
Aitor Viana Sanchez
aitor.viana.sanchez at esa.int
Fri Jun 5 09:10:28 UTC 2015
Hi there,
I ported some time ago CANfestival to RTEMS and got it running for RASTA
boards from GR.
I'd need to go thru my computer files if you're interested.
regards
//avs
On 04/06/15 17:06, scorbo wrote:
> Hi,
> Does a CANopen library exist on RTEMS ?
> Thanks,
> users mailing list
> users at rtems.org
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
URL: <http://lists.rtems.org/pipermail/users/attachments/20150605/249c4e12/attachment-0001.html>
