Best way to update RTEMS?
Mon Jun 8 20:25:53 UTC 2015
After pulling, it is a good idea to:
1. re-run bootstrap, in case any of the autoconf input files have
changed (Makefile.am, preinstall.am, configure.ac).
2. re-run configure, in case bootstrap changed any of the autoconf
output files (configure, Makefile.in)
3. re-run make, in case configure changed any of its outputs (Makefile)
The cleanest thing to do is to delete your build directory--where you
previously have run configure and make, which should not be the same
as your source (rtems.git) directory.
Gedare
On Mon, Jun 8, 2015 at 3:25 PM, Wu, Mark H. <Mark.H.Wu at disney.com> wrote:
> I started with a fresh directory, ran configure and make, and it built fine. Is configure supposed to update the directory when a new pull is done, or is it make that's supposed to update things?
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Friday, June 05, 2015 18:48
> To: Wu, Mark H.; users at rtems.org
> Subject: Re: Best way to update RTEMS?
> On 6/06/2015 11:11 am, Wu, Mark H. wrote:
>> I downloaded RTEMS from the git repo a few weeks ago, and have things at a stable point (still working on getting a few things to work, like networking). I decided to update from the git repo, and can't seem to get it rebuilt correctly. What are the correct steps to update my libraries after pulling down from the repo?
> How did you update RTEMS ? I normally do a 'git pull'.
>> What I have done so far:
>> 1. Run ./bootstrap within the RTEMS directory
>> 2. Re-run configure from within my installation directory
>> 3. Re-run make from within my installation directory
> Just to clear up any misunderstanding, we use the term 'source'
> directory for the location of the RTEMS source code we are building. We
> term the 'installation' directory the locate the files the 'make
> install' process installs RTEMS to, ie the configure's -prefix path.
>> This is where it fails - I have a compilation error. The files within my installation directory don't quite match the ones in the RTEMS directory.
>> I believe that these are the same steps I performed upon initial installation (the same steps in the quick start). Do they not work for updating? Is there another (better) procedure for updating RTEMS?
> What is your configure command line ?
> What is the error ?
> The error all depends on the point you took your initial build from.
> There was a change in newlib that effected the RTEMS kernel source and
> that requires an RSB update and a rebuild of your tools.
> Please note, this type of change does not happen on releases and once
> 4.11 is released you will experience a stable environment.
> Chris
> users mailing list
> users at rtems.org
