error while compling libbsd (cannot find rtems/timecounter.h)
Tue Jun 9 05:18:52 UTC 2015
On 9/06/2015 3:13 pm, Sebastian Huber wrote:
> You need the latest RSB based tool chain and RTEMS version.  I think you are only able to build on SPARC using the waf builder for libbsd.  I am not sure if there is a driver for SPARC in libbsd currently.
I am building with ...
 --rtems-bsps=arm/realview_pbx_a9_qemu,arm/xilinx_zynq_a9_qemu
so any BSP should build. There a few corner cases in the BSPs where
tweaks are needed because the exported pkgcfg files are missing
somethings present in export makefile support (due to horrible BSP hacks).
