libbsd.txt "test runner" realview_pbx_a9_qemu
Gene Smith gds at chartertn.net
Tue Jun 9 06:20:38 UTC 2015
On 06/03/2015 03:07 AM, Sebastian Huber wrote:
> Hello Gene,
> the test runner are available via the rtems-testing repository.  You may
> need the attached Qemu patches.
Yes, I think Chris also pointed out the need for these patches (or in my
case, maybe I only need the realview.c patch).
Is there a way to apply these patches automatically, say, in
qemu-git.1.cfg ??  The problem seems to be that RSB always does a pull
from the qemu remote and overwrites the patches that I manually applied
in the RSB created qemu.git directory. There are other patches done in
qemu-git.1.cfg but I don't really understand how the "%patch" lines work
when a local patch needs to be done (or if this is possible).
-gene
> On 02/06/15 21:35, Gene Smith wrote:
>> Have been attempting to follow the instructions in libbsd.txt and it
>> mentions a "test runner" but doesn't say what that means. Based on the
>> contents of config.inc, it appears to be the bsp name,
>> realview_pbx_a9_qemu, but make install of libbsd does not seem to
>> produce a file with that name.
>> I also assume I may also need qemu installed but not sure.
>> Under realview-pbx-a9 bsp there are instructions for building qemu
>> from a particular git snapshot:
>> git checkout a1bff71c56f2d1048244c829b63797940dd4ba0e
>> However, for me the qemu build fails with this snapshot. But if I
>> build from
>> git checkout master
>> qemu builds OK.
>> Any help or pointers on this would be appreciated.
>> -gene
>> users mailing list
>> users at rtems.org
