Best way to update RTEMS?
Mr. Andrei Chichak groups at chichak.ca
Tue Jun 9 17:23:04 UTC 2015
If it helps at all, due to this thread, I decided to do a git pull and update RTEMS.
Of course, the pull only brings in the source that has changed, it doesn’t recompile everything. So I typed make and broke everything, doh! Just doing a make is not adequate.
From my crap memory and a couple of scripts, I managed to blow away all of my tools and the source. I started again at source-builder, but that only gave me the tools. As a user, I figure that that should actually be called tool-builder, but I digress.
Eventually I did a git clone to get me back to where I should have started, then used my script that looks like:
./bootstrap -c
./bootstrap
configure  (bunch of stuff)
make (other stuff)
and I was back on the air.
So, I went onto a different system, did a git pull and the bootstrap/configure/make commands from above and it worked nicely.
My questions are: When SHOULD I be doing git pulls? How do we find out when the tools and source have incompatible changes and need to run tool-builder?
Andrei
> On 2015-June-09, at 10:55 AM, Wu, Mark H. <Mark.H.Wu at disney.com> wrote:
> Interesting. I'll try those next time. But I did follow the steps below (bootstrap, configure, make), and it didn't resolve the problem. I had to start with a clean directory to get it to work again.
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Monday, June 08, 2015 22:11
> To: Gedare Bloom
> Cc: Wu, Mark H.; users at rtems.org
> Subject: Re: Best way to update RTEMS?
> Hello,
> in most cases it is enough to run configure with the --enable-mainainer-mode option and then do a "make preinstall" in an existing build tree.  If you get strange errors, then do the below steps.
> ----- Gedare Bloom <gedare at rtems.org> schrieb:
>> After pulling, it is a good idea to:
>> 1. re-run bootstrap, in case any of the autoconf input files have
>> changed (Makefile.am, preinstall.am, configure.ac).
>> 2. re-run configure, in case bootstrap changed any of the autoconf
>> output files (configure, Makefile.in)
>> 3. re-run make, in case configure changed any of its outputs (Makefile)
>> The cleanest thing to do is to delete your build directory--where you
>> previously have run configure and make, which should not be the same
>> as your source (rtems.git) directory.
>> Gedare
>> On Mon, Jun 8, 2015 at 3:25 PM, Wu, Mark H. <Mark.H.Wu at disney.com> wrote:
>>> I started with a fresh directory, ran configure and make, and it built fine. Is configure supposed to update the directory when a new pull is done, or is it make that's supposed to update things?
>>> From: Chris Johns [mailto:chrisj at rtems.org]
>>> Sent: Friday, June 05, 2015 18:48
>>> To: Wu, Mark H.; users at rtems.org
>>> On 6/06/2015 11:11 am, Wu, Mark H. wrote:
>>>> I downloaded RTEMS from the git repo a few weeks ago, and have things at a stable point (still working on getting a few things to work, like networking). I decided to update from the git repo, and can't seem to get it rebuilt correctly. What are the correct steps to update my libraries after pulling down from the repo?
>>> How did you update RTEMS ? I normally do a 'git pull'.
>>>> What I have done so far:
>>>> 1. Run ./bootstrap within the RTEMS directory
>>>> 2. Re-run configure from within my installation directory
>>>> 3. Re-run make from within my installation directory
>>> Just to clear up any misunderstanding, we use the term 'source'
>>> directory for the location of the RTEMS source code we are building. We
>>> term the 'installation' directory the locate the files the 'make
>>> install' process installs RTEMS to, ie the configure's -prefix path.
>>>> This is where it fails - I have a compilation error. The files within my installation directory don't quite match the ones in the RTEMS directory.
>>>> I believe that these are the same steps I performed upon initial installation (the same steps in the quick start). Do they not work for updating? Is there another (better) procedure for updating RTEMS?
>>> What is your configure command line ?
>>> What is the error ?
>>> The error all depends on the point you took your initial build from.
>>> There was a change in newlib that effected the RTEMS kernel source and
>>> that requires an RSB update and a rebuild of your tools.
>>> Please note, this type of change does not happen on releases and once
>>> 4.11 is released you will experience a stable environment.
>>> Chris
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
