Problem with rtems_event_send crashing from interrupt routine
Mr. Andrei Chichak groups at chichak.ca
Wed Jun 10 19:36:12 UTC 2015
> On 2015-June-10, at 1:26 PM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> Hello Andrei,
> which RTEMS version do you use?
Sorry about that, 4.11 updated to the head earlier this week, with the tools rebuilt earlier this week using source-builder.
A
> ----- Mr. Andrei Chichak <groups at chichak.ca> schrieb:
>> This one is weird (for me).
>> I’m dealing with an STM32F407 (ARM M4F), stripping data off of the ADCs using DMA.  Using double buffering, I get an interrupt telling me that my ADC scan is done and the data is waiting in region “A”, then 1/200 of a second later I get a different interrupt telling me that data is waiting in region “B”, repeat.
>> To indicate to my task that the buffer is ready I use rtems_event_send in the interrupt routine and either send RTEMS_EVENT_0 or RTEMS_EVENT_1, depending on which interrupt routine got called.
>> The task does a:
>> 		status = rtems_event_receive( RTEMS_EVENT_0 | RTEMS_EVENT_1, RTEMS_WAIT | RTEMS_EVENT_ANY, 100, &events);
>> and this is seen to run 200 times per second.
>> BUT, after (exactly and repeatably) 3101 seconds the receive no longer happens and never return with a status code. Actually the process seems to go into an infinite loop outside of my code.
> In which function is this infinite loop?
