Problem with rtems_event_send crashing from interrupt routine
Fri Jun 12 19:02:40 UTC 2015
On Fri, Jun 12, 2015 at 1:33 PM, Mr. Andrei Chichak <groups at chichak.ca> wrote:
> Does it make any sense that I can bypass the problem with the watchdogs by
> calling rtems_event_receive with a timeout of RTEMS_NO_TIMEOUT?
Yes, the event will not go into the watchdog if there is no time out.
(However, chasing this bug down a little bit is beneficial to others.
Or posting a test case that demonstrates it.)
> Andrei
> users mailing list
> users at rtems.org
