attaching an interrupt in beaglebone bsp
Angelo Fraietta
newsgroups at smartcontroller.com.au
Mon Jun 15 00:17:22 UTC 2015
I got an error on first part of tutorial
angelo at debian:~/development/rtems/sources$ git clone -b beagle
https://github.com/bengras/rtems-source-builder.git
Cloning into rtems-source-builder...
remote: Counting objects: 5104, done.
remote: Total 5104 (delta 0), reused 0 (delta 0), pack-reused 5104
Receiving objects: 100% (5104/5104), 3.22 MiB | 694 KiB/s, done.
Resolving deltas: 100% (3163/3163), done.
./rtems-source-builder/source-builder/sb-
sb-bootstrap sb-check sb-reports sb-set-builder
sb-builder sb-defaults sb-rtems-config
./rtems-source-builder/source-builder/sb-check
RTEMS Source Builder - Check, v0.5.0
error: exe: not found: (__bison) /usr/bin/bison
error: exe: not found: (__cvs) /usr/bin/cvs
error: exe: not found: (__flex) /usr/bin/flex
On Mon, Apr 13, 2015 at 10:14 PM, Andrew Harris <andrew.unit at gmail.com>
wrote:
> Hello,
> I'm not sure how to attach an interrupt in the beaglebone ARM bsp. I
> learned that the "rtems_interrupt_catch" method of binding an interrupt to
> an ISR won't work by noticing that the CPU_SIMPLE_VECTORED_INTERRUPTS is
> set to FALSE in cpu.h for the beaglebone BSP. I want to try binding an
> interrupt from the I2C Bus 1 into RTEMS, but I'm not sure where to go next
> in terms of how to attach the interrupt. Any help would be appreciated.
> -andrew
> users mailing list
> users at rtems.org
On Mon, Jun 1, 2015 at 6:06 PM, Ben Gras <beng at shrike-systems.com> wrote:
> Hi Angelo,
> Nice to hear of your interest!
> This tutorial covers everything from scratch and I recently verified the
> instructions work & the built result works :).
> http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
> Personally I've been using Ubuntu 14.04 to build lately. Not my first
> choice in working environment but it's what I have at the moment.
> On Mon, Jun 1, 2015 at 7:27 AM, angelo fraietta <
> newsgroups at smartcontroller.com.au> wrote:
>> I have been given go-ahead to actually start looking at testing
>> beaglebone with RTEMS.
>> Does anyone have the most current instructions for building and running
>> on BB.
>> Also, what platforms are people using for development?
>> Thanks
>> On 13/04/2015 10:14 PM, Andrew Harris wrote:
>> Hello,
>> -andrew
>> users mailing listusers at rtems.orghttp://lists.rtems.org/mailman/listinfo/users
>> [image: Avast logo] <http://www.avast.com/>
>> This email has been checked for viruses by Avast antivirus software.
>> www.avast.com
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150615/0bfb8f1a/attachment.html>
