error while compling libbsd (cannot find rtems/timecounter.h)
Mon Jun 15 19:40:42 UTC 2015
Double-check that your tools and rtems source are correctly updated
and installed. It sounds like the other user got past this point on
SPARC.
-Gedare
On Mon, Jun 15, 2015 at 3:27 PM, Yurii Shevtsov <ungetch at gmail.com> wrote:
> 2015-06-15 22:10 GMT+03:00 Gedare Bloom <gedare at rtems.org>:
>> Yurii,
>> I misread this, when you said 'error left'. Anyways, are you getting
>> an error related to pci.h?
> I can't say for sure. It refuses to compile ev_streams.c from libc, so
> why are you asking about pci.h?
>> Gedare
>> On Fri, Jun 12, 2015 at 6:25 PM, Yurii Shevtsov <ungetch at gmail.com> wrote:
>>> Got the same error but for RPi. Just updated rtems and RSB, error
>>> left. Also error is buildsystem independent
>>> [ 27/684] c: freebsd/lib/libc/isc/ev_streams.c ->
>>> build/arm-rtems4.11-raspberrypi/freebsd/lib/libc/isc/ev_streams.c.8.o
>>> In file included from
>>> /home/gtament/development/rtems/src/myrtems-libbsd/freebsd/lib/libc/include/isc/eventlib.h:29:0,
>>>                  from ../../freebsd/lib/libc/isc/ev_streams.c:40:
>>> /home/gtament/development/rtems/src/myrtems-libbsd/rtemsbsd/include/rtems/bsd/sys/time.h:35:31:
>>> fatal error: rtems/timecounter.h: No such file or directory
>>> Thanks in advance)
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
