attaching an interrupt in beaglebone bsp
Wed Jun 17 03:57:15 UTC 2015
On 6/16/2015 8:52 PM, Chris Johns wrote:
> On 17/06/2015 9:48 am, Angelo Fraietta wrote:
>> So I replace
>> %define qemu_version ac0bfdb9c310276521e5b089d7f36c1f610ca60b
>> with
>> %define qemu_version e571600c4a260d3072abbe7ecf2013e48e82bea7
> Yes.
>> (I don't want top break anything)
> The RSB should take care of the rest and it should put the git repo it
> has cloned in the correct state.
I updated to a commit within the past 24 hours and got the same result on
Centos 6.
lt LINK vscclient
   LINK  qemu-bridge-helper
/usr/bin/ld: -f may not be used without -shared
collect2: ld returned 1 exit status
make: *** [vscclient] Error 1
make: *** Waiting for unfinished jobs....
shell cmd failed: /bin/sh -ex  /home/joel/rtems-4.11-work/rtems-source-builder/bare/build/qemu-93f6d1c16036aaf34055d16f54ea770fb8d6d280-i686-linux-gnu-1/doit
error: building qemu-93f6d1c16036aaf34055d16f54ea770fb8d6d280-i686-linux-gnu-1
This appears to be the same as this issue on launchpad.
https://bugs.launchpad.net/qemu/+bug/1258168
I haven't looked into it much but that is from 2014 so should be merged
already.
FWIW doing a make -k, it appears that this is the only build error on
CentOS 6.
Interestingly, I moved over to the CentOS 7.1 and it failed here:
install: cannot stat '/data/home/joel/rtems-4.11-work/rtems-source-builder/bare/build/qemu-93f6d1c16036aaf34055d16f54ea770fb8d6d280-x86_64-linux-gnu-1/qemu-93f6d1c16036aaf34055d16f54ea770fb8d6d280/pc-bios/vgabios-virtio.bin': No such file or directory
Please double check me on the analysis of the launchpad report and
see if it is the same. I have no idea what the Centos 7 issue is but
that file does not appear to be in the current source. It could have
been removed and the install stanza not updated.
> Chris
> users mailing list
> users at rtems.org
